[Qgis-user] data defined style with $scale
Bernhard Ströbl bernhard.stroebl at jena.de
Mon Nov 18 23:58:39 PST 2013
Hi Stefan,
agreed, but a data-defined style does not produce a proper legend either
(at least not in all cases). It will contain lesser items, though.
Bernahrd
Am 19.11.2013 08:51, schrieb Ziegler Stefan:
> Hi Bernard
> Thanks. If you have a lot of rules for the same style in different scales you end up with a unreadable legend.
> Stefan
>> -----Ursprüngliche Nachricht-----
>> Von: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] Im
>> Auftrag von Bernhard Ströbl
>> Gesendet: Dienstag, 19. November 2013 08:28
>> An: qgis-user at lists.osgeo.org
>> Betreff: Re: [Qgis-user] data defined style with $scale
>> Hi Stefan,
>> neither a solution nor an answer but a workaround:
>> I always use the rule based renderer and set the scale for the rule (I _think_ this may
>> also be faster)
>> Bernhard
>> Am 19.11.2013 07:50, schrieb Ziegler Stefan:
>>> Hi
>>> I have a question regarding data defined styling. I'm using the $scale parameter to
>> define the line width:
>>> CASE
>>> WHEN $scale<= 500.0 THEN 1
>>> WHEN ($scale>   500 AND $scale<= 1000) THEN 0.5 END
>>> I would expect that the line is not drawn with a scale larger than 1000. But it seems
>> the line is still drawn. It even draws the line with an ELSE-statement:
>>> CASE
>>> WHEN ($scale>   500 AND $scale<= 1000) THEN 0.5 ELSE 0.0 END
>>> It seems that I get my expected result when I use an ELSE value near zero (e.g.
>> 0.0000001).
>>> Is this on purpose? Or is there an error in my statement?
>>> regards
>>> Stefan
>>> Freundliche Grüsse
>>> Stefan Ziegler
>>> Kantonsgeometer
>>> Amt für Geoinformation
>>> Amtliche Vermessung
>>> Rötistrasse 4
>>> 4500 Solothurn
>>> Telefon +41 32 627 75 96
>>> Telefax +41 32 627 75 98
>>> stefan.ziegler at bd.so.ch
>>> http://www.so.ch
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> __________ Information from ESET Mail Security, version of virus
>>> signature database 9065 (20131118) __________
>>> The message was checked by ESET Mail Security.
>>> http://www.eset.com
>> __________ Information from ESET Mail Security, version of virus signature database
>> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 9065 (20131118) __________
http://www.eset.com
