[Qgis-user] data defined style with $scale
Andreas Neumann
a.neumann at carto.net
Tue Nov 19 02:59:12 PST 2013
Hi Stefan,
This seems logical to me. The data-defined styling only changes a
graphical property. It does not control whether a feature is drawn or
not. You could set it to fully transparent, but this would still fetch
features and draw them (though invisible).
If you want to suprress features above a certain level you may do that
on the layer level in the "General settings" (or something similar).
The labels individually allow to suppress labels based on a column or
expression, but the data-defined symbology does not allow that so far.
It would be a new feature to ask for.
Andreas
Am 2013-11-19 07:50, schrieb Ziegler Stefan:
> Hi
> I have a question regarding data defined styling. I'm using the $scale
> parameter to define the line width:
> CASE
> WHEN $scale <= 500.0 THEN 1
> WHEN ($scale > 500 AND $scale <= 1000) THEN 0.5
> END
> I would expect that the line is not drawn with a scale larger than
> 1000. But it seems the line is still drawn. It even draws the line
> with an ELSE-statement:
> CASE
> ELSE 0.0
> END
> It seems that I get my expected result when I use an ELSE value near
> zero (e.g. 0.0000001).
> Is this on purpose? Or is there an error in my statement?
> regards
> Stefan
> Freundliche Grüsse
> Stefan Ziegler
> Kantonsgeometer
> Amt für Geoinformation
> Amtliche Vermessung
> Rötistrasse 4
> 4500 Solothurn
> Telefon +41 32 627 75 96
> Telefax +41 32 627 75 98
> stefan.ziegler at bd.so.ch
> http://www.so.ch
> Qgis-user mailing list
