[Qgis-user] raster artefact in composer pdf export
Michael Spencer
spencer.mike.r at gmail.com
Thu Nov 21 12:23:58 PST 2013
Problem solved using detail Radim added to the raised issue:
http://hub.qgis.org/issues/9101
I removed null values - problem solved!
On 20 November 2013 16:24, Michael Spencer <spencer.mike.r at gmail.com> wrote:
> Hi Radim and list,
> I've been trying to get around this as described, by saving the raster
> with the same projection as the project. Unfortunately, I'm still getting
> the same artefact when I export to pdf. How else can I get around this
> issue?
> Ta,
> Michael
> On 15 November 2013 10:48, Radim Blazek <radim.blazek at gmail.com> wrote:
>> I am able to reproduce it with reprojected raster, the dashed lines
>> appear on original raster extent border. Until we fix that, the only
>> solution I see is to save reprojected raster and use not reprojected
>> raster in composition.
>> Please create the issue anyway.
>> Radim
>> On Fri, Nov 15, 2013 at 11:29 AM, Radim Blazek <radim.blazek at gmail.com>
>> wrote:
>> > On Thu, Nov 14, 2013 at 6:33 PM, Michael Spencer
>> >> Hi all,
>> >> Just updating a figure I originally produced in v1.8 without problem.
>> The
>> >> aerial photo now generates a dashed line (top and bottom) artefact
>> when I
>> >> export to pdf.
>> >> Example here: http://ubuntuone.com/5OmDksQ5O8ppjAX4172ctl
>> > Please create a new issue and attach a small raster + project with
>> > comosition reproducing the problem.
>> > The raster is reprojected?
>> > The raster is using resampling?
>> > Radim
>> >> Any ideas how to fix it?
>> >> Ta,
>> >> Michael
>> >> ps copyright to appear in figure caption ;)
>> >> _______________________________________________
>> >> Qgis-user mailing list
>> >> Qgis-user at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131121/15611815/attachment.html>
