[Qgis-user] Which port does qgis use to connect to wms, wfs, ... plugin repository?
Marco Lechner - FOSSGIS e.V. marco.lechner at fossgis.de
Tue Oct 15 07:03:53 PDT 2013
Hi rob,
if your OGC services are starting with http:// QGIS will use :80 as it
is the used protocols standard port. There's nothing specific about it.
If you can surf the internet QGIS should be able to use http:// based
services.
Marco
Am 15.10.2013 15:54, schrieb rob vech:
> Hello all,
> I enjoyed to use qgis (2.0.1 dufour) in my research work and I'd like
> to use it in my hydrological class.
> The computers room that I use has very limited security rules and so,
> only port 80 is open for external connection (mainly html).
> That is probably the reason why I cannot connect to external services
> like WMS, WFS ... that work fine with my pc!
> I'd like to know if there is any possibility to know which port qgis
> uses to make connections (so I can ask to the room administrator to
> open it!) or if there is some way to change it to 80, that is already
> free.
> Thank you very much
> rob
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131015/70e5da15/attachment.html>
