[Qgis-user] Which port does qgis use to connect to wms, wfs, ... plugin repository?
Richard Duivenvoorde rdmailings at duif.net
Tue Oct 15 07:09:37 PDT 2013
On 15-10-13 16:03, Marco Lechner - FOSSGIS e.V. wrote:
> Hi rob,
> if your OGC services are starting with http:// QGIS will use :80 as it
> is the used protocols standard port. There's nothing specific about it.
> If you can surf the internet QGIS should be able to use http:// based
> services.
IF you have https://... (mind the S: httpS:// which is 'secure http')
you will need port 443 open
But as Marco says: most wms servers run on normal http port == 80.
Another thing that comes to mind: maybe you are connecting to geoserver
instances? Which run in servlet containters, which often run on port 8080
But all this has nothing to do with QGIS :-) it is all just networking
stuff...
Which brings me to the next hurdle... is the lab using a proxy server?
If so: you need to make it known to QGIS too.
Regards,
