[Qgis-user] Invalid parameter in Graphical modeler crashes QGIS
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Sat Oct 19 04:25:58 PDT 2013
Dear list,
QGIS crashes/freezes when a wrong parameter (which is not defined) is
inserted in the algorithm (usually when trying to edit the algorithm).
I get this error message in terminal:
Warning: QLayout: Attempting to add QLayout "" to
ModelerParameterDefinitionDialog "", which already has a layout
QGIS died on signal 11
There is a similar bug here:
http://hub.qgis.org/issues/6785
Cheers
Saber
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
