[Qgis-user] problems with dbf encoding in Chugiak
William Kyngesburye
woklist at kyngchaos.com
Fri Aug 1 06:55:40 PDT 2014
I've also noticed problems with shapefile encodings, though it seemed random. Maybe it's just a general problem of QGIS ignoring the cpg file. To work around it, set the encoding in the layer properties after adding it to QGIS.
On Aug 1, 2014, at 3:29 AM, Agustin Diez-Castillo <gvsig.mac at gmail.com> wrote:
> Hi,
> I'm having problems to see the correct encoding of this file [1]. To the best of my understanding the original encoding is 1252 and this works in LibreOffice or other gis programs, however trying to read it in Qgis gives always the wrong result (spanish characters missed). I've try the fix dbf encoder plugin adding the cpg file but with no success.
> I'm on mac running Kyngchaos version.
> Can somebody test the attached file and see what's going on?
> Thanks
> [1] https://www.dropbox.com/s/zeh5vdx8b2g1lxb/BCN200_0301L_RIO.zip
> QGIS version2.4.0-ChugiakQGIS code revisionCompiled against Qt4.8.6Running against Qt4.8.6Compiled against GDAL/OGR1.11.0Running against GDAL/OGR1.11.0Compiled against GEOS3.4.2-CAPI-1.8.2Running against GEOS3.4.2-CAPI-1.8.2 r3921PostgreSQL Client Version9.3.4SpatiaLite Version4.1.1QWT Version6.0.2PROJ.4 Version480QScintilla2 Version2.8.1
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
