[Qgis-user] problems with dbf encoding in Chugiak
Borys Jurgiel
lists at borysjurgiel.pl
Fri Aug 1 10:39:07 PDT 2014
For me it looks good, but I don't speak Spanish so please take a look at the
screen shot and confirm: http://tmp.borysjurgiel.pl/cp1252.png
Also please note the "Ignore shapefile encoding" checkbox in QGIS settings.
If it's enabled, you can (and you need to) select the proper encoding when
opening the layer. You can also change it in layer properties. As the declared
encoding is ignored, changes made by Shapefile Encoding Fixer don't take any
effect.
If the checkbox is disabled, the autodetection is active, so you can't
manually select encoding (if I remember correctly, the list in the "open
layer" window is ignored, the one in layer properties is disabled). Instead,
you can use the Shapefile Encoding Fixer to control the encoding declaration.
So in short, they are two opposite modes.
Best regards,
Borys
Dnia piÄ…tek, 1 sierpnia 2014 08:55:40 William Kyngesburye pisze:
> I've also noticed problems with shapefile encodings, though it seemed
> random. Maybe it's just a general problem of QGIS ignoring the cpg file.
> To work around it, set the encoding in the layer properties after adding it
> to QGIS.
> On Aug 1, 2014, at 3:29 AM, Agustin Diez-Castillo <gvsig.mac at gmail.com>
wrote:
> > Hi,
> > I'm having problems to see the correct encoding of this file [1]. To the
> > best of my understanding the original encoding is 1252 and this works in
> > LibreOffice or other gis programs, however trying to read it in Qgis
> > gives always the wrong result (spanish characters missed). I've try the
> > fix dbf encoder plugin adding the cpg file but with no success. I'm on
> > mac running Kyngchaos version.
> > Can somebody test the attached file and see what's going on?
> > Thanks
> > [1] https://www.dropbox.com/s/zeh5vdx8b2g1lxb/BCN200_0301L_RIO.zip
> > QGIS version2.4.0-ChugiakQGIS code revisionCompiled against Qt4.8.6Running
> > against Qt4.8.6Compiled against GDAL/OGR1.11.0Running against
> > GDAL/OGR1.11.0Compiled against GEOS3.4.2-CAPI-1.8.2Running against
> > GEOS3.4.2-CAPI-1.8.2 r3921PostgreSQL Client Version9.3.4SpatiaLite
> > Version4.1.1QWT Version6.0.2PROJ.4 Version480QScintilla2 Version2.8.1
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those least
> suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
