[Qgis-user] Newbie issue with layers
Mike Flannigan
mikeflan at att.net
Fri Aug 8 11:56:28 PDT 2014
Howdy.
I assume you have checked and unchecked the black
'X' next to each layer in the "Layers" window and
each layer turns on and off as you check them?
Also try a 'zoom to layer' for the csv layer.
Perhaps this is just a case of not having a
negative sign in front of the long, so your
points are on the other side of the world.
Mike
On 8/8/2014 1:24 PM, qgis-user-request at lists.osgeo.org wrote:
> Hello all:
> I am a very new user of QGIS (v. 2.4) on a Windows installation. I have a SHP file and a CSV file with good geocoded addresses in the area delineated by the SHP file. However, I cannot get the layers to display together. I have turned off "Control rendering order," checked the transparency of the layers, and can't figure out what else is wrong. I searched the documentation and didn't find anything else.
> Any suggestions are very much appreciated.
> Thank you.
