[Qgis-user] Enhancing Raster Images
G. Garibaldi
digitalmaps at cox.net
Tue Aug 12 14:18:21 PDT 2014
Ah, don't blend.
On 8/12/2014 2:28 PM, Siki Zoltan wrote:
> Hi,
> I suppose blending is not the best solution, because i depends on
> other layers.
> Why don't you use transparancy tab of the properties of the raster?
> There you can set pixel values to be transparent (0-100%). In your
> case from 0 to 0 value 100% transparent
> Then change render type to Singleband pseudocolor on the style tab and
> set individual color for any value.
> In your case add 1 to the list and select a color for it.
> Zoltan
> On Tue, 12 Aug 2014, G. Garibaldi wrote:
>> Beginning with a black and white raster, black lines on a white
>> background, I'd like to end up with a raster image with no white
>> background with only the black lines showing. Additionally, I'd like
>> the black lines to be a different color, bright red, bright green, etc.
>> This is what I've done:
>> Select raster layer properties>color rendering>blending mode>burn.
>> This removes the white background and shows only the black lines.
>> Going further and selecting properties>hue>colorize only lightly
>> tints the black lines to the selected color, not really the desired
>> result.
>> How can I make the properties>hue>colorize change the black lines to
>> some bright highly saturated color?
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140812/775f2ac2/attachment.html>
