[Qgis-user] Reverting to version 2.2 from 2.4
    Damien Stephens
    Damien.Stephens at sandfire.com.au
    Tue Aug 19 00:03:51 PDT 2014
Hi if all you want is to get open layers back. Just upgrade the plugin (plugins\manage and install plugins\   select  open layers plugin then upgrade.
The layers move to the WEB menu from the PLUGINS menu across the top, but other than that they are identical, and I think there are improvements in how the open layers plugin works as well - seems to be more stable. I cant tell which OSM plugin you need but I guess they will have been upgraded too.
cheers
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Laura O'Grady
Sent: Tuesday, 19 August 2014 6:21 AM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Reverting to version 2.2 from 2.4
Hi all,
I'm using a Windows 7 64-bit machine. I downloaded the installer (osgeo4w-setup-x86_64.exe) in the fall of 2013 when I purchased, "Learning QGIS 2.0" book in the fall of 2013. I only recently installed it and was slightly surprised to see version 2.2 install instead of 2.0. I assumed this would not be an issue for the tutorials I was going to use to teach myself the program.
I was following one particular QGIS tutorial online through Canvas when I was required to install a package in order to complete the task. As a result QGIS upgraded to version 2.4, which broke some plug-ins (specifically open layers, OSM) that I was using.
I would like to know what is the best method to complete the following tasks:
(1). Remove version 2.4 and ensure there are no hooks remaining on my computer
(2). Re-install version 2.2 (I'm assuming it would be download it from here: http://qgis.org/downloads/ , specifically the file QGIS-OSGeo4W-2.2.0-1-Setup-x86_64.exe, dated February 26, 2014)
(3). Ensure that adding packages in the future doesn't automatically upgrade my version to 2.2 to 2.X.
I can understand the generic installer I was using a few months ago to install what I thought was 2.0 actually installed 2.2 but I think I should have been asked/warned about the version change from 2.2 to 2.4. Thanks.
Laura
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140819/269daf44/attachment.html>
