[Qgis-user] reposting q on reprojection problem in QGIS > 2.0
Andre Joost
andre+joost at nurfuerspam.de
Tue Jul 1 08:40:10 PDT 2014
Am 01.07.2014 14:48, schrieb Peter Aldhous:
> Hi all,
> Apologies for reviving this thread (below), but does anyone have a
> solution other than using a different data format? I ask because I will
> be do some teaching using QGIS and want to work with shapefiles for that.
> This is a problem that's emerged for me only with recent versions of
> QGIS, so something must have changed to cause the behavior. Might it be
> at the level of GDAL?
A simple solution is to cut the data at 180°E/W.
I described a detailed workflow for QGIS or GDAL here:
http://gis.stackexchange.com/questions/102009/convert-shapefiles-from-wgs84-to-miller-projection
HTH,
André Joost
