[Qgis-user] Wrong area with OTF activated
Gino Pirelli
luipir at gmail.com
Fri Jul 4 00:06:38 PDT 2014
what is your destination (OTF) crs?
On 3 July 2014 17:37, Carlos Cerdán <sig.upagu at gmail.com> wrote:
> Dear QGIS users
> I was preparing a question about calculating areas because I had an issue:
> calculated area in QGIS was different (and wrong) that ArcGIS (right value)
> ... but i found the answer. It can be useful for your work (as it was for
> mine) so here is a comment:
> I was working in UTM src (SRC = 32717, in notification, down right
> corner), but with "on the fly SRC transformation" activated. When I use
> field calculator, the value of area is greater (and wrong) than when it's
> calculated with "on the fly.." deactivated (right area value).
> So, in QGIS, the right way to make geometry calculus is matching SRC of
> your project and your layers and working deactivating "on the fly..."
> Greetings
> Carlos
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140704/6aafe4ff/attachment.html>
