[Qgis-user] QGIS Web Client - QWC Issues loading map (server loads fine)
Carlos da Ponte
cdaponte at sustainableelements.ca
Fri Jul 11 00:32:40 PDT 2014
Played with this a lot today, and the only thing that fixed the issue was to
change the WMS service in the gs files to WMS 1.0 from WMS 1.3
So now a map with load, correctly zoomed to the projectsettings extents, but
some layers are loading unchecked as if they have no data (which is not the
case). This issue appears to only be an issue with the MSSQL Server layers
we pull in and even then its tempermental and happens at random. Does this
have to do with the Bounding Box for the layers being empty? A couple of my
layers actually have a feature count of -1 ? (not the case).
http://gis.idn12.com/qgis/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.0&REQUEST=GetCapabilities&map=c:/projects/elements/theme_fn2.qgs
http://gis.idn12.com/qgiswebclient.html?map=C:/projects/elements/theme_fn2.qgs
These examples show that while the 3 layers have the same data source (msql
server) only features on two of the layers actually show up in QWC (First
Nations Reserve and Intent Boundaries)
anyone have any thoughts on what issue still remains?
Thanks for the help..Its really appreciated
C
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-Web-Client-QWC-Issues-loading-map-server-loads-fine-tp5150233p5150610.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
