[Qgis-user] Selecting rasters with vector layer
    Eric Goddard
    egoddard1010 at gmail.com
    Mon Mar  3 16:51:31 PST 2014
Yes, you should be able to choose ECW from the files of type drop down in
the output file selection dialog and select ECW.
Eric
On Mon, Mar 3, 2014 at 4:48 PM, Asher Kamiraze <asher.kamiraze at gmail.com>wrote:
> Thanks Eric, sounds really good. Is there a way to save the resulting file
> (clipped) as an ECW file? I need to process it later with a 3rd party
> software.
> Regards
> 2014-03-03 23:26 GMT+01:00 Eric Goddard <egoddard1010 at gmail.com>:
> Hi asher, if you go to raster -> miscellaneous, there is a menu entry
>> called build virtual raster catalog. You can use that to virtually mosaic
>> all of your ECW files. This tool creates a new file you can load in as a
>> raster that references all of the individual ECW files to display them
>> seamlessly in qgis without having to spend the time to actually mosaic all
>> of them together. Load the resulting vrt file into qgis using add raster
>> and clip the vrt to your polygon layer using raster -> extraction ->
>> clipper.
>> Eric
>> On Mar 3, 2014 3:53 PM, "Asher Kamiraze" <asher.kamiraze at gmail.com>
>> wrote:
>>> Hi all,
>>> I have a set of more than 200 ecw rasters that I can easily load in
>>> QGIS. I also have a vector polygon layer which bounds an area covering a
>>> part of the area covered by the whole set of rasters. What I would like to
>>> do is to extract only, the raster which are intersected by the vector
>>> boundary. As a final goal, I would like to only mosaic thoses images. I did
>>> not found a way to easily do this in QGIS. Any idea on how to achieve this?
>>> As a workaround, I have opened only the raster intersecting the vector,
>>> and would like to mosaic them. However, it does not seem to be a function
>>> in QGIS ready to mosaic all opened (or selected) rasters. Any idea on how
>>> to automate the process?
>>> Hope you could help
>>> Regards
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140303/faa0642f/attachment.html>
