[Qgis-user] Symbology Export
    Jonathan Moules
    jonathanmoules at warwickshire.gov.uk
    Mon Mar 10 07:49:35 PDT 2014
Hi Andreas,
Thanks for the information. I'd suggest it should probably be removed
until/unless it is fleshed out as you note. Either that or changed to be a
"Datasource option" specific for DXF.
Should I open a ticket for this?
Cheers,
Jonathan
On 10 March 2014 14:35, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Jonathan,
> This was originally introduced for DXF export to keep symbology as good
> as it can - which is now in its separate function (Project -> DXF
> Export) and not in the "save layer as" anymore.
> It uses the OGR feature styling, which in itself is rather limiting.
> This isn't widely implemented and tested. Would be nice if some devs or
> interested customers/users could give it some love.
> Andreas
> Am 10.03.2014 13:45, schrieb Jonathan Moules:
> > Hi List,
> > General curiosity question.
> > When using "Save Vector Layer as" to save a vector layer, there's an
> > optioon:
> > "Symbology Export"
> > This in turn has three options:
> > "No Symbology"
> > "Feature symbology"
> > "Symbol layer symbology"
> > What does this do? I've tried exporting to both KML and TAB files using
> > these options but they don't appear to keep the symbology.
> > Cheers,
> > Jonathan
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140310/ea4c7def/attachment.html>
