[Qgis-user] QGIS 2.6 projected graticules
Lester Anderson
arctica1963 at gmail.com
Sun Nov 2 06:17:45 PST 2014
Hi all
Part of the solution (or workaround) is to use the Vector ->Research Tools
-> Vector Grid option
This gives the lines reasonably well when projected, but the nodes need to
be increased (densified) to give the curved latitudes etc.
Does this sound reasonable?
Still have to label manually
So, not impossible to find a partial solution, but hopefully this will be
built-in eventually. QGIS is a great piece of kit and I am sure it will
gain momentum!
On 2 November 2014 13:08, Ramon AndiƱach <custard at westnet.com.au> wrote:
> On 02/11/2014, at 19:50 , Lester Anderson wrote:
> > Hi all,
> > Still no built-in option in the composer for projected map graticules
> (eg Polar stereographic, Lambert conformal etc). Still limited to linear
> systems.
> > Will this ever be implemented in QGIS, or is there a plugin that will
> create projected map graticules for all projections (to display longitude
> and latitude)?
> > I have been using QGIS since v1.6 and have seen no changes on this
> aspect.
> Well, no. Not no movement, but you might want to look into some of the new
> features a bit before saying that it's not possible.
> This image https://www.dropbox.com/s/j8rjxb6om1ciuau/Polar.png?dl=0 is
> about 2 minutes playing and has a grid on an arctic polar map. I don't
> think it can be perfect, but it's a lot closer. Is that almost what you
> where after?
> Significantly for you one of the nice developers[1] added a feature that
> allows you to draw grids in different projections to the map canvas. It
> might be worth asking him nicely what it would cost to have what you need
> added (e.g. some work on the labels, and some way to show that missing 180
> line.), and then banding together with some other folk that work in high
> and low places to make it happen.
> -ramon.
> [1] My thanks by the way. I realise that there's been an ongoing argument
> about the accuracy of being able to do this (which I don't want to
> restart), but sometimes this is what the client wants - and its nice to be
> able to do it without too much mucking about.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141102/19161168/attachment.html>
