[Qgis-user] QGIS 2.6 projected graticules
Alex Mandel tech_dev at wildintellect.com
Sun Nov 2 08:38:41 PST 2014
My hack was to write a short python script that does a more dense line
(You choose the spacing between lines, default nodes are every degree I
think).
https://github.com/wildintellect/pyGraticule
Then I cut it to extent and project it into the final projection I want.
The extra density makes it easier to label what you want to. However the
table values are always in Lat/Lon so you'll need to use the field
calculator to pull out the X/Y after projection if you wanted projected
coordinate labels.
Maybe someday I'll have time to add the idea to QGIS directly.
Thanks,
Alex
On 11/02/2014 06:17 AM, Lester Anderson wrote:
> Hi all
> Part of the solution (or workaround) is to use the Vector ->Research Tools
> -> Vector Grid option
> This gives the lines reasonably well when projected, but the nodes need to
> be increased (densified) to give the curved latitudes etc.
> Does this sound reasonable?
> Still have to label manually
> So, not impossible to find a partial solution, but hopefully this will be
> built-in eventually. QGIS is a great piece of kit and I am sure it will
> gain momentum!
> On 2 November 2014 13:08, Ramon AndiƱach <custard at westnet.com.au> wrote:
>> On 02/11/2014, at 19:50 , Lester Anderson wrote:
>>> Hi all,
>>> Still no built-in option in the composer for projected map graticules
>> (eg Polar stereographic, Lambert conformal etc). Still limited to linear
>> systems.
>>> Will this ever be implemented in QGIS, or is there a plugin that will
>> create projected map graticules for all projections (to display longitude
>> and latitude)?
>>> I have been using QGIS since v1.6 and have seen no changes on this
>> aspect.
>> Well, no. Not no movement, but you might want to look into some of the new
>> features a bit before saying that it's not possible.
>> This image https://www.dropbox.com/s/j8rjxb6om1ciuau/Polar.png?dl=0 is
>> about 2 minutes playing and has a grid on an arctic polar map. I don't
>> think it can be perfect, but it's a lot closer. Is that almost what you
>> where after?
>> Significantly for you one of the nice developers[1] added a feature that
>> allows you to draw grids in different projections to the map canvas. It
>> might be worth asking him nicely what it would cost to have what you need
>> added (e.g. some work on the labels, and some way to show that missing 180
>> line.), and then banding together with some other folk that work in high
>> and low places to make it happen.
>> -ramon.
>> [1] My thanks by the way. I realise that there's been an ongoing argument
>> about the accuracy of being able to do this (which I don't want to
>> restart), but sometimes this is what the client wants - and its nice to be
>> able to do it without too much mucking about.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
