[Qgis-user] Creating DEM from ASCII Coordinates
    berounba
    beroubt at gmail.com
    Sat Nov  8 05:56:34 PST 2014
My ASCII values are regular gridded (are there?) like:
 (That is beginning and ending of the ASCII-File in ESPG:31468)
 4460690  5550999 320.85
 4460691  5550999 320.90
 4460692  5550999 320.92
 4460693  5550999 320.92
 4460694  5550999 320.90
 4460695  5550999 320.92
 4460696  5550999 320.81
 4460697  5550999 320.67
 4460698  5550999 320.64
 4460699  5550999 320.74
 4460700  5550999 320.80
 4460701  5550999 320.71
 4460702  5550999 320.59
 4461150  5551000 323.81
 4461151  5551000 323.71
 4461152  5551000 323.62
 4461153  5551000 323.53
 4461154  5551000 323.42
 4461155  5551000 323.35
 4461156  5551000 323.26
Using Raster -> Conversion -> Translate I've got the error
	ERROR 1: At line 1, found 5550999.000000 instead of 5551154.000000
for nBlockYOff = 0
	ERROR 1: X:/tmp/DGM/DGM 1/DGM_dgm.txt, band 1: IReadBlock failed at
X offset 0, Y offset 2+
Running Raster -> Analysis -> Grid on the layer after RMC save as Shapefile
results in an GeoTIFF-File with "nan"-Values
What is going wrong?
___________________________________________________________-
-----Ursprüngliche Nachricht-----
Von: qgis-user-bounces at lists.osgeo.org
[mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Andre Joost
Gesendet: Freitag, 7. November 2014 10:24
An: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] Creating DEM from ASCII Coordinates
Am 07.11.2014 um 09:16 schrieb berounba:
> Hi all,
> I have a ASCII-File with x-/y-/z-Values.
> For using in QGIS2threejs is is necessary to have a DEM. I assume it
> is a geoTIF. Is there possibility to convert the Vector-Layer (ASCI
> Values) to a DEM or may be a plug in?
If the ASCII file follows a regular grid, you can load the file into QGIS
using XYZ format, and create a tif file with Raster -> Conversion
-> Translate.
If the points do not form a regular grid, you have to load the data as
delimited text, save it to Shapefile format, then run Raster -> Analysis
-> Grid on the layer.
HTH,
André Joost
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
