[Qgis-user] Duplicating a vector layer
Randal Hale
rjhale at northrivergeographic.com
Thu Nov 13 09:11:03 PST 2014
Probably the easiest thing for you to do is to right click on the layer
and go to "save as". That will save/export your current layer as a new
one and allow the edits you want to make. All you would need to do is
add it to you qgis session.
Hope that helps,
Randy
On 11/13/2014 11:38 AM, Adrian Beasley wrote:
> I am new to QGIS, still very much learning how to use it.
> What I wish to do is generate a number of similar vector layers, to be
> able to generate slightly different maps from them. The obvious way
> would seem to be to duplicate an existing layer, renaming the new
> copy, and editing it. But this seems not to produce a new, distinct
> layer, as making changes to either the original or the new layer
> causes the same changes in both.
> I can find no mention of this facility in the user guide nor in the
> training documentation. Can anyone help?
> Thanks in anticipation.
> Adrian Beasley
> Qgis-user mailing list
Randal Hale
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale http://about.me/rjhale
http://www.northrivergeographic.com/spatial-connect
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141113/85f3d0b3/attachment.html>
