[Qgis-user] Add WMS in QGIS gives an error with Map request failed [error:Host http not found url:http://http//
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Sun Nov 30 10:17:23 PST 2014
Strunck, Alexander GIZ PS <alexander.strunck at ...> writes:
> Dear Mathias,
> Thank you for the suggestion. I tried this already.
> If I enter only
> [IP]:11188/mapviewer/wms
> QGIS than changes it into
I can't reproduce with a Geoserver WMS that is running in a non-default port
by using connection
"http://[IP]:10080/geoserver/wms"
Without getting an access to that certain WMS or some other Oracle server
that shows the same odd behaviour and is open for everybody it is hard to
help you. You can still do GetCapabilities request and study carefully the
response. I think that the most probable reason is a wrong GetMap URL that
the service is announcing but unchecking the cross as you already did should
help in such case.
-Jukka Rahkonen-
