[Qgis-user] Different vertical and horizontal scales
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Mon Apr 13 10:34:55 PDT 2015
Yes.  All pixel that are in Lat/Lon are rectangular but look square on
the screen if projected in Lat/Lon.  They will look like rectangles if
reprojected in meter (using projection on the fly). Be careful when
saving the file in an other projection.  If you don't specify the number
of pixels, QGIS will try to change the pixel shape to squares.
Nicolas
Le 2015-04-13 13:25, simonc8 [via OSGeo.org] a écrit :
> I am creating a project using a Geographical lat and lon coordinate
> reference system (it's ED50). At the latitude I'm working one degree
> of lat
> is approx twice as long as one degree of lon so maps look roughly like
> true
> scale if you set the latitude scale (in degrees per cm) half the
> longitude
> scale.
> Is there a way I can do this with QGIS?
> Grateful for advice.
> Qgis-user mailing list
> [hidden email] </user/SendEmail.jtp?type=node&node=5201140&i=0>
> If you reply to this email, your message will be added to the
> discussion below:
> http://osgeo-org.1560.x6.nabble.com/Different-vertical-and-horizontal-scales-tp5201140.html
> To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==>.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Different-vertical-and-horizontal-scales-tp5201140p5201144.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150413/fddcb654/attachment.html>
