[Qgis-user] LasTools use in QGIS 2.8.1
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Thu Apr 23 07:10:19 PDT 2015
Select any file then modify the path after. If there is no file (should not be the case here), create a dummy .txt.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
On Apr 23, 2015 12:59 AM, "luigi.s102 [via OSGeo.org]" <ml-node+s1560n5202575h86 at n6.nabble.com> wrote:
I'm new in the QGIS world, and I have to convert a shp point file in las; I have seen that the Lastools is embedded in QGIS 2.8.1 in the folder C:\Program Files\QGIS Wien\apps\qgis\python\plugins\processing\algs\lidar; in the Options under Processing menu is required, in the file browser dialog, a file instead of a folder as indicated, in the option program dialog, and thus I don't know how to continue I'm thankful for any Your hint in this matter Regards Luigi
Connetti gratis il mondo con la nuova indoona: hai la chat, le chiamate, le video chiamate e persino le chiamate di gruppo.
E chiami gratis anche i numeri fissi e mobili nel mondo!
Scarica subito l’app Vai su https://www.indoona.com/ _______________________________________________
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/LasTools-use-in-QGIS-2-8-1-tp5202575.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/LasTools-use-in-QGIS-2-8-1-tp5202575p5202682.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150423/eca43b96/attachment.html>
