[Qgis-user] authentication when using 'Import Vector into PostGIS database (available connections)'
Torsten Lange
torsten.lange at mail.de
Tue Apr 28 06:12:47 PDT 2015
I Larissa,
it's Postgresql complaining that no user name is provided for the request. Do you have a valid connection initialised befor between QGis and PostGIS?
Torsten
Am 28-Apr-2015 14:36:31 +0200 schrieb junek at gbd-consult.de:
Hello,
I'm currently checking out 'Import Vector into PostGIS database
(available connections)' from the processing algorithms for the user
manual.
I have started my database connection with 'rcpostgresql start' and
then filled in the parameters of the a.m. import tool. In 'History and
log' is documented:
GDAL execution console output
ERROR 1: PQconnectdb failed.
FATAL: kein PostgreSQL-Benutzername im Startpaket angegeben (= given no
PostgreSQL-username in the starter kit)
How can I authenticate to the database so that the vector layer will be
imported? Which additional steps are to be done?
Kind regards,
Larissa
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150428/947e6368/attachment.html>
