[Qgis-user] Fw: authentication when using 'Import Vector into PostGIS database (available connections)'
Torsten Lange torsten.lange at mail.de
Tue Apr 28 07:00:42 PDT 2015
If you would use SPIT (in the Database menu), then you could create a connection to your PostGIS-DB. In the dialog you have to provide your user name (password). Click the New or Neu button (depending on the language of your QGIS installation) in order to create the connection you need. Then you should be able to upload your vector layers.
Torsten
  Anfang der weitergeleiteten E-Mail
Von: junek at gbd-consult.de
 An: torsten.lange at mail.de
 Datum: 28-Apr-2015 15:26:43 +0200
 Betreff: Re: [Qgis-user] authentication when using 'Import Vector into PostGIS database (available connections)'
 Hello Torsten,
 anyway if I don't use the GDAL algorithm for the task but the QGIS
 Algorithm 'Import into PostGIS' the import works fine...
 Sorry, I just used 'postgresql start'. How can I initialize a valid
 connection between QGIS and PostGIS as a first step? The GDAL algorithm
 seems to be complicated in use from processing. And I will have to
 describe all this information in the user manual ...)-:
 Thanks.
 Kind regards,
 Larissa
 Am Tue, 28 Apr 2015 14:58:43 +0200
 schrieb Torsten Lange :
 > I Larissa,
 > it's Postgresql complaining that no user name is provided for the
 > request. Do you have a valid connection initialised befor between
 > QGis and PostGIS?
 > Torsten
 > Am 28-Apr-2015 14:36:31 +0200 schrieb junek at gbd-consult.de:
 > Hello,
 > I'm currently checking out 'Import Vector into PostGIS database
 > (available connections)' from the processing algorithms for the user
 > manual.
 > I have started my database connection with 'rcpostgresql start' and
 > then filled in the parameters of the a.m. import tool. In 'History
 > and log' is documented:
 > GDAL execution console output
 > ERROR 1: PQconnectdb failed.
 > FATAL: kein PostgreSQL-Benutzername im Startpaket angegeben (= given
 > no PostgreSQL-username in the starter kit)
 > How can I authenticate to the database so that the vector layer will
 > be imported? Which additional steps are to be done?
 > Kind regards,
 > Larissa
 > Qgis-user mailing list
 Geoinformatikbüro Dassau GmbH
 Rethelstrasse 153
 D - 40237 Düsseldorf
 Tel: +49-211-69937750
 Fax: +49-211-69937751
 Mobile: +49-171-4687540
http://www.gbd-consult.de
 Registergericht: Amtsgericht Düsseldorf, HR B 74022
 Geschäftsführer: Otto Dassau
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150428/a990f284/attachment.html>
