[Qgis-user] Fw: authentication when using 'Import Vector into PostGIS database (available connections)'
Larissa Junek
junek at gbd-consult.de
Tue Apr 28 07:15:36 PDT 2015
Thanks for the tip. But I inted to desrcibe the procedure when using
the processing GDAL/OGR algorithm 'Import Vector into PostGIS database
(available connections)'.
Maybe somebody else can give me a description?
Cheers,
Larissa
Am Tue, 28 Apr 2015 16:00:42 +0200
schrieb Torsten Lange <torsten.lange at mail.de>:
> If you would use SPIT (in the Database menu), then you could create a
> connection to your PostGIS-DB. In the dialog you have to provide your
> user name (password). Click the New or Neu button (depending on the
> language of your QGIS installation) in order to create the connection
> you need. Then you should be able to upload your vector layers.
> Torsten
> Anfang der weitergeleiteten E-Mail
> Von: junek at gbd-consult.de
> An: torsten.lange at mail.de
> Datum: 28-Apr-2015 15:26:43 +0200
> Betreff: Re: [Qgis-user] authentication when using 'Import Vector
> Hello Torsten,
> anyway if I don't use the GDAL algorithm for the task but the QGIS
> Algorithm 'Import into PostGIS' the import works fine...
> Sorry, I just used 'postgresql start'. How can I initialize a valid
> connection between QGIS and PostGIS as a first step? The GDAL
> algorithm seems to be complicated in use from processing. And I will
> have to describe all this information in the user manual ...)-:
> Thanks.
> Kind regards,
> Larissa
> Am Tue, 28 Apr 2015 14:58:43 +0200
> schrieb Torsten Lange :
> > I Larissa,
> > it's Postgresql complaining that no user name is provided for the
> > request. Do you have a valid connection initialised befor between
> > QGis and PostGIS?
> > Torsten
> > Am 28-Apr-2015 14:36:31 +0200 schrieb junek at gbd-consult.de:
> > Hello,
> > I'm currently checking out 'Import Vector into PostGIS database
> > (available connections)' from the processing algorithms for the
> > user manual.
> > I have started my database connection with 'rcpostgresql start' and
> > then filled in the parameters of the a.m. import tool. In 'History
> > and log' is documented:
> > GDAL execution console output
> > ERROR 1: PQconnectdb failed.
> > FATAL: kein PostgreSQL-Benutzername im Startpaket angegeben (=
> > given no PostgreSQL-username in the starter kit)
> > How can I authenticate to the database so that the vector layer
> > will be imported? Which additional steps are to be done?
> > Kind regards,
> > Larissa
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Geoinformatikbüro Dassau GmbH
> Rethelstrasse 153
> D - 40237 Düsseldorf
> Tel: +49-211-69937750
> Fax: +49-211-69937751
> Mobile: +49-171-4687540
> http://www.gbd-consult.de
> Registergericht: Amtsgericht Düsseldorf, HR B 74022
> Geschäftsführer: Otto Dassau
Rethelstrasse 153
