[Qgis-user] QGIS - Phase 1 Habitat Style Query
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Mon Feb 16 07:39:55 PST 2015
Hi Colin,
The first part of your question, as long as they are of the same geometry type (e.g. all polygon), you can store them in 1 file. But if you are working with ESRI Shapefiles, you can’t have multiple geometry type (e.g. point and polygon) in the same layer.
The second part of your email: when you zoom in too close to Google map, the image shifts. Therefore any layer you are digitising will be shifted too.
Cheers,
Saber
Saber Razmjooei
Lutra Consulting
www.lutraconsulting.co.uk <http://www.lutraconsulting.co.uk/>
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Colin Bonfield
Sent: 16 February 2015 10:27
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] QGIS - Phase 1 Habitat Style Query
To Whom it may concern,
Please could I submit the following query:
I have managed to load a style for JNCC Phase 1 Habitat Mapping as follows: settings – style manager – share – import – then browse to and select the file. Then I just created a poly, line or point for each habitat and selected the style. Can this be done within a single poly layer or am I correct creating a layer for each style used i.e. amenity grassland, improved grassland.
The problem I still have is when digitising over a Google aerial (I used this in preference to Bing because you can zoom in closer) if I move the map all the shape files shift out of place, very frustrating! If you know how to overcome this please could you let me know. I’m sure I will probably come across other problems when I come to creating a layouts and legends etc but will post these queries later.
Kind regards
Colin
Colin Bonfield BSc (Hons), MSc, MCIEEM
Senior Ecologist
Acorn Ecology Limited
The Granary, Westpoint, Sidmouth Road, Clyst St Mary, Exeter, EX5 1DJ
T: 01392 366512
E: colinbonfield at acornecology.co.uk
<http://www.acornecology.co.uk/> www.acornecology.co.uk
www.ecologytraining.co.uk
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell pro
ducts, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150216/b8b2a786/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150216/b8b2a786/attachment.jpg>
