[Qgis-user] export map from map composer
Torsten Lange
torsten.lange at mail.de
Thu Feb 19 21:42:22 PST 2015
Hi Andreas,
thanks - though late :) - for your suggestion. I'll check that out at next possibility!
Torsten
Am 09-Feb-2015 12:26:20 +0100 schrieb a.neumann at carto.net:
Hi Torsten,
Not sure what exactly you want/need - but it sounds like you want a serial print over many map frames or objects. This can be solved using the Atlas serial printing.
Before you start working on this you should make sure you are at the latest QGIS version (2.6.1) - because the serial printing was improved in the latest 1-2 releases.
Then you can look in the QGIS manual and search for Atlas printing - or Google and find some blog entries. This should help you get started.
You can even manipulate page format/sizes in the serial print, if this is what you want.
Good luck,
Andreas
On 09.02.2015 11:37, Torsten Lange wrote:
is there a more easy way to export a map composition to an image file? I see, that I can limit the map by changing the vertical/horizontal page extent. But if I want to prepare many simple map overviews of different sizes and aspect ratios for a report, I'd prefer to have a dialog saying - "only the limits of the map" or so.
Have I missed this feature or do I always have to manually fit the page to the map by changing the numbers of page vertical/horizontal extent?
Thanks, Torsten
_______________________________________________ Qgis-user mailing list Qgis-user at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150220/55499e24/attachment.html>
