[Qgis-user] [Qgis-developer] QGIS 2.8.2 for RHEL/EPEL 7
Tudorache, Marian Marian.Tudorache at navcanada.ca
Tue Jun 16 08:38:15 PDT 2015
Hi Dave,
I was looking into this new python-OWSLib and I ended up with the same cyclic  dependency around phonon-4.6.0-9.el7.x86_64.rpm and also there is dependency on python-requests that wasn’t before.
Is it OK to replace with phonon-4.7.1-1..ram0.99.x86_64.rpm?
By the way I am looking to get some assistance to install the application in Linux.
I am in Ottawa.
Thanks,
Marian
From: Dave Johansen [mailto:davejohansen at gmail.com]
Sent: June-15-15 1:20 PM
To: Tudorache, Marian
Cc: richard at duif.net; Matthias Kuhn; Alex Mandel; Angelos Tzotsos; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-developer] QGIS 2.8.2 for RHEL/EPEL 7
On Mon, Jun 15, 2015 at 10:07 AM, Tudorache, Marian <Marian.Tudorache at navcanada.ca<mailto:Marian.Tudorache at navcanada.ca>> wrote:
Hi again,
I forgot to mention what work around I did to solve the circular dependency.
I replaced the package phonon-4.6.0-9.el7.x86_64.rpm with phonon-4.7.1-1..ram0.99.x86_64.rpm.
Doing this I was able to install PyQt4-4.10.1-13.el7.x86_64.rpm
https://admin.fedoraproject.org/updates/python-OWSLib-0.9.0-1.el7
python-OWSLib has been submitted to the testing repo for EPEL 7 and should be available later today.
phonon 4.6.0 is the version that comes with RHEL/CentOS so I'm guessing that you have some 3rd party repos and/or packages installed and that is the real source of the issue that you're running into. If you can reproduce this issue with just the RHEL/CentOS and EPEL repos, then please let me know.
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150616/82a80a36/attachment.html>
