[Qgis-user] RPM for RHEL6 based OS's please.
~Stack~
i.am.stack at gmail.com
Tue Jun 30 15:51:34 PDT 2015
Greetings,
I never found an RPM for RHEL6 and I am _still_ struggling with getting
QGIS to compile. I have found lots of information for Debian/Ubuntu but
nothing really for RHEL6.
It has taken me a lot of time to track down all of the dependencies (a
surprising amount are not caught by the ccmake so I have to wait for the
compile to die and track down why). I now get about ~16% into the
compile and it dies with linker problems between two files it just
compiled!! Doh!
I would really appreciate some help.
Thanks!
The only change I made (because qt4 is too old apparently):
$ git diff
diff --git a/CMakeLists.txt b/CMakeLists.txt
index ae7294c..a113b34 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -246,7 +246,7 @@ ENDIF(WITH_QTWEBKIT)
-SET (ENABLE_QT5 FALSE CACHE BOOL "If enabled will try to find Qt5
before looking for Qt4")
+SET (ENABLE_QT5 TRUE CACHE BOOL "If enabled will try to find Qt5 before
looking for Qt4")
Here is the basic idea of what I did after a git clone (did a fresh pull
this morning):
$ cd ~/Code/QGIS
$ mkdir build-master
$ cd build-master
$ ccmake ..
$ make
Here are all the packages I had to install:
bakefile-0.2.8-3.el6.x86_64
cfitsio-3.240-3.el6.x86_64
fftw2-2.1.5-21.el6.x86_64
gdal-1.7.3-15.el6.x86_64
gdal-devel-1.7.3-15.el6.x86_64
gdal-java-1.7.3-15.el6.x86_64
geos-3.3.2-1.el6.x86_64
grass-devel-6.4.4-6.el6.x86_64
grass-libs-6.4.4-6.el6.x86_64
libXp-1.0.2-2.1.el6.x86_64
libXp-devel-1.0.2-2.1.el6.x86_64
libdap-3.11.0-1.el6.x86_64
libgeotiff-1.2.5-6.el6.x86_64
libgeotiff-devel-1.2.5-6.el6.x86_64
librx-1.5-24.el6.x86_64
libtiff-devel-3.9.4-10.el6_5.x86_64
netcdf-4.1.1-3.el6.5.x86_64
ogdi-3.2.0-0.14.beta2.el6.x86_64
openmotif-2.3.3-8.el6.x86_64
openmotif-devel-2.3.3-8.el6.x86_64
proj-4.7.0-1.el6.x86_64
proj-devel-4.7.0-1.el6.x86_64
python-empy-3.3-5.el6.noarch
unixODBC-2.2.14-14.el6.x86_64
wxGTK-devel-2.8.12-1.el6.x86_64
wxPython-devel-2.8.12.0-1.el6.x86_64
xerces-c-3.0.1-20.el6.x86_64
geos-devel-3.3.2-1.el6.x86_64
sqlite-devel-3.6.20-1.el6.x86_64
libspatialite-2.4.0-0.6.RC4.el6.x86_64
libspatialite-devel-2.4.0-0.6.RC4.el6.x86_64
qt5-qtbase-5.4.2-2.el6.x86_64
qt5-qtbase-common-5.4.2-2.el6.noarch
qt5-qtbase-devel-5.4.2-2.el6.x86_64
qt5-qtbase-gui-5.4.2-2.el6.x86_64
xcb-util-image-0.3.9-4.el6.x86_64
xcb-util-keysyms-0.3.9-5.el6.x86_64
xcb-util-wm-0.3.9-5.el6.x86_64
qt5-qtsvg-5.4.2-1.el6.x86_64
qt5-qtsvg-devel-5.4.2-1.el6.x86_64
geoclue-0.11.1.1-0.13.20091026git73b6729.el6.x86_64
qt5-qtdeclarative-5.4.2-2.el6.x86_64
qt5-qtdeclarative-devel-5.4.2-2.el6.x86_64
qt5-qtlocation-5.4.2-1.el6.x86_64
qt5-qtlocation-devel-5.4.2-1.el6.x86_64
qt5-qtwebkit-5.4.2-1.el6.x86_64
qt5-qtwebkit-devel-5.4.2-1.el6.x86_64
qt5-qttools-5.4.2-1.el6.x86_64
qt5-qttools-common-5.4.2-1.el6.noarch
qt5-qttools-devel-5.4.2-1.el6.x86_64
qt5-qttools-libs-clucene-5.4.2-1.el6.x86_64
qt5-qttools-libs-designer-5.4.2-1.el6.x86_64
qt5-qttools-libs-designercomponents-5.4.2-1.el6.x86_64
qt5-qttools-libs-help-5.4.2-1.el6.x86_64
bluez-libs-4.66-1.el6.x86_64
openal-soft-1.12.854-1.el6.x86_64
qt5-qtconnectivity-5.4.2-1.el6.x86_64
qt5-qtconnectivity-devel-5.4.2-1.el6.x86_64
qt5-qtmultimedia-5.4.2-1.el6.x86_64
qt5-qtmultimedia-devel-5.4.2-1.el6.x86_64
qt5-qtquick1-5.4.2-1.el6.x86_64
qt5-qtquick1-devel-5.4.2-1.el6.x86_64
qt5-qtscript-5.4.2-1.el6.x86_64
qt5-qtscript-devel-5.4.2-1.el6.x86_64
qt5-qtsensors-5.4.2-1.el6.x86_64
qt5-qtsensors-devel-5.4.2-1.el6.x86_64
qt5-qtserialport-5.4.2-1.el6.x86_64
qt5-qtserialport-devel-5.4.2-1.el6.x86_64
qt5-qtwebchannel-5.4.2-1.el6.x86_64
qt5-qtwebchannel-devel-5.4.2-1.el6.x86_64
qt5-qtwebsockets-5.4.2-1.el6.x86_64
qt5-qtwebsockets-devel-5.4.2-1.el6.x86_64
qt5-qtx11extras-5.4.2-1.el6.x86_64
qt5-qtx11extras-devel-5.4.2-1.el6.x86_64
qt5-qtxmlpatterns-5.4.2-1.el6.x86_64
qt5-qtxmlpatterns-devel-5.4.2-1.el6.x86_64
PyQt4-devel-4.6.2-9.el6.x86_64
python-devel-2.6.6-52.el6.x86_64
sip-devel-4.9.3-1.el6.x86_64
gsl-1.13-1.el6.x86_64
gsl-devel-1.13-1.el6.x86_64
expat-devel-2.0.1-11.el6_2.x86_64
PyQwt-5.2.0-11.el6.x86_64
PyQwt-devel-5.2.0-11.el6.x86_64
numpy-1.4.1-9.el6.x86_64
python-nose-0.10.4-3.1.el6.noarch
python-setuptools-0.6.10-3.el6.noarch
qwt-5.1.1-4.1.el6.x86_64
qwt-devel-5.1.1-4.1.el6.x86_64
qscintilla-2.4-1.el6.x86_64
qscintilla-devel-2.4-1.el6.x86_64
spatialindex-1.6.1-3.el6.x86_64
spatialindex-devel-1.6.1-3.el6.x86_64
qwtpolar-0.1.0-5.el6.x86_64
qwtpolar-devel-0.1.0-5.el6.x86_64
qt5-qttools-static-5.4.2-1.el6.x86_64
qt-mobility-1.1.3-2.el6.x86_64
qtwebkit-2.1.1-1.el6.x86_64
qtwebkit-devel-2.1.1-1.el6.x86_64
And this is as far as I have gotten with this compile:
$ make
Scanning dependencies of target version
[ 0%] Generating qgsversion.h
[ 0%] Built target version
[ 0%] Generating gps/moc_qgsqtlocationconnection.cpp
[ 0%] Generating flex_qgsexpressionlexer.cpp
[ 0%] Generating qgsexpressionparser.cpp
[ 0%] Generating moc_qgsapplication.cpp
[ 0%] Generating moc_qgsbrowsermodel.cpp
[ 0%] Generating moc_qgscontexthelp.cpp
[ 0%] Generating moc_qgscoordinatetransform.cpp
[ 0%] Generating moc_qgsdataitem.cpp
[ 0%] Generating moc_qgsdataprovider.cpp
[ 0%] Generating moc_qgsgml.cpp
[ 0%] Generating moc_qgsgmlschema.cpp
[ 0%] Generating moc_qgsmaplayer.cpp
[ 0%] Generating moc_qgsmaplayerlegend.cpp
[ 0%] Generating moc_qgsmaplayerregistry.cpp
[ 0%] Generating moc_qgsmaplayerstylemanager.cpp
[ 0%] Generating moc_qgsmaprenderer.cpp
[ 0%] Generating moc_qgsmaprenderercache.cpp
[ 0%] Generating moc_qgsmaprenderercustompainterjob.cpp
[ 0%] Generating moc_qgsmaprendererjob.cpp
[ 0%] Generating moc_qgsmaprendererparalleljob.cpp
[ 1%] Generating moc_qgsmaprenderersequentialjob.cpp
[ 1%] Generating moc_qgsmessageoutput.cpp
[ 1%] Generating moc_qgsmessagelog.cpp
[ 1%] Generating moc_qgsnetworkreplyparser.cpp
[ 1%] Generating moc_qgsnetworkcontentfetcher.cpp
[ 1%] Generating moc_qgsofflineediting.cpp
[ 1%] Generating moc_qgscredentials.cpp
[ 1%] Generating moc_qgspluginlayer.cpp
[ 1%] Generating moc_qgspointlocator.cpp
[ 1%] Generating moc_qgsproject.cpp
[ 1%] Generating moc_qgsrunprocess.cpp
[ 1%] Generating moc_qgsrelationmanager.cpp
[ 1%] Generating moc_qgssnappingutils.cpp
[ 1%] Generating moc_qgsvectorlayer.cpp
[ 1%] Generating moc_qgsvectorlayereditpassthrough.cpp
[ 1%] Generating moc_qgsvectorlayereditbuffer.cpp
[ 1%] Generating moc_qgsnetworkaccessmanager.cpp
[ 1%] Generating moc_qgsvectordataprovider.cpp
[ 1%] Generating moc_qgsvectorlayercache.cpp
[ 1%] Generating moc_qgsvectorlayerjoinbuffer.cpp
[ 1%] Generating moc_qgsgeometryvalidator.cpp
[ 1%] Generating moc_qgswebview.cpp
[ 1%] Generating composer/moc_qgsaddremoveitemcommand.cpp
[ 1%] Generating composer/moc_qgscomposerlegend.cpp
[ 1%] Generating composer/moc_qgscomposermap.cpp
[ 1%] Generating composer/moc_qgscomposermapitem.cpp
[ 1%] Generating composer/moc_qgscomposermapgrid.cpp
[ 1%] Generating composer/moc_qgscomposermapoverview.cpp
[ 1%] Generating composer/moc_qgscomposerpicture.cpp
[ 1%] Generating composer/moc_qgscomposerscalebar.cpp
[ 1%] Generating composer/moc_qgscomposerobject.cpp
[ 1%] Generating composer/moc_qgscomposeritem.cpp
[ 2%] Generating composer/moc_qgscomposeritemgroup.cpp
[ 2%] Generating composer/moc_qgscomposermousehandles.cpp
[ 2%] Generating composer/moc_qgscomposerlabel.cpp
[ 2%] Generating composer/moc_qgscomposershape.cpp
[ 2%] Generating composer/moc_qgscomposerattributetable.cpp
[ 2%] Generating composer/moc_qgscomposerattributetablev2.cpp
[ 2%] Generating composer/moc_qgscomposerattributetablemodel.cpp
[ 2%] Generating composer/moc_qgscomposerattributetablemodelv2.cpp
[ 2%] Generating composer/moc_qgscomposertable.cpp
[ 2%] Generating composer/moc_qgscomposertablev2.cpp
[ 2%] Generating composer/moc_qgscomposertablecolumn.cpp
[ 2%] Generating composer/moc_qgscomposertexttable.cpp
[ 2%] Generating composer/moc_qgscomposerhtml.cpp
[ 2%] Generating composer/moc_qgscomposermultiframe.cpp
[ 2%] Generating composer/moc_qgscomposereffect.cpp
[ 2%] Generating composer/moc_qgsatlascomposition.cpp
[ 2%] Generating composer/moc_qgscomposermodel.cpp
[ 2%] Generating composer/moc_qgscomposition.cpp
[ 2%] Generating composer/moc_qgslegendmodel.cpp
[ 2%] Generating raster/moc_qgsrasterlayer.cpp
[ 2%] Generating raster/moc_qgsrasterdataprovider.cpp
[ 2%] Generating gps/moc_qgsgpsconnection.cpp
[ 2%] Generating gps/moc_qgsgpsdetector.cpp
[ 2%] Generating gps/moc_qgsnmeaconnection.cpp
[ 2%] Generating gps/moc_qgsgpsdconnection.cpp
[ 2%] Generating symbology-ng/moc_qgscptcityarchive.cpp
[ 2%] Generating symbology-ng/moc_qgssvgcache.cpp
[ 2%] Generating symbology-ng/moc_qgsstylev2.cpp
[ 2%] Generating layertree/moc_qgslayertreegroup.cpp
[ 2%] Generating layertree/moc_qgslayertreelayer.cpp
[ 2%] Generating layertree/moc_qgslayertreemodel.cpp
[ 2%] Generating layertree/moc_qgslayertreemodellegendnode.cpp
[ 2%] Generating layertree/moc_qgslayertreenode.cpp
[ 3%] Generating layertree/moc_qgslayertreeregistrybridge.cpp
[ 3%] Generating gps/qextserialport/moc_qextserialport.cpp
[ 3%] Generating gps/qextserialport/moc_qextserialenumerator.cpp
Scanning dependencies of target qgis_core
[ 3%] Building CXX object
src/core/CMakeFiles/qgis_core.dir/gps/qgsgpsconnection.cpp.o
src/core/CMakeFiles/qgis_core.dir/gps/qgsgpsconnectionregistry.cpp.o
src/core/CMakeFiles/qgis_core.dir/gps/qgsnmeaconnection.cpp.o
src/core/CMakeFiles/qgis_core.dir/gps/qgsgpsdconnection.cpp.o
src/core/CMakeFiles/qgis_core.dir/gps/qgsgpsdetector.cpp.o
[ 3%] Building C object src/core/CMakeFiles/qgis_core.dir/gps/parse.c.o
[ 3%] Building C object src/core/CMakeFiles/qgis_core.dir/gps/sentence.c.o
[ 3%] Building C object src/core/CMakeFiles/qgis_core.dir/gps/info.c.o
[ 3%] Building C object src/core/CMakeFiles/qgis_core.dir/gps/time.c.o
[ 3%] Building C object src/core/CMakeFiles/qgis_core.dir/gps/gmath.c.o
[ 3%] Building C object src/core/CMakeFiles/qgis_core.dir/gps/tok.c.o
[ 3%] Building C object src/core/CMakeFiles/qgis_core.dir/gps/context.c.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgssymbolv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgssymbollayerv2.cpp.o
/home/user/Code/QGIS/src/core/symbology-ng/qgssymbollayerv2.cpp: In
member function ‘virtual const QgsExpression*
QgsSymbolLayerV2::dataDefinedProperty(const QString&) const’:
/home/user/Code/QGIS/src/core/symbology-ng/qgssymbollayerv2.cpp:95:
warning: ‘virtual QgsExpression* QgsSymbolLayerV2::expression(const
QString&) const’ is deprecated (declared at
/home/user/Code/QGIS/src/core/symbology-ng/qgssymbollayerv2.h:262)
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgssymbollayerv2registry.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgssymbollayerv2utils.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgslegendsymbolitemv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgslinesymbollayerv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsmarkersymbollayerv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsfillsymbollayerv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsrendererv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsrendererv2registry.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgssinglesymbolrendererv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgscategorizedsymbolrendererv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsgraduatedsymbolrendererv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsrulebasedrendererv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsheatmaprenderer.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsinvertedpolygonrenderer.cpp.o
[ 4%] Building CXX object
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsvectorcolorrampv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgscptcityarchive.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsstylev2.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgssymbologyv2conversion.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgssvgcache.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsellipsesymbollayerv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgspointdisplacementrenderer.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgsvectorfieldsymbollayer.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/qgscolorbrewerpalette.cpp.o
src/core/CMakeFiles/qgis_core.dir/diagram/qgsdiagram.cpp.o
src/core/CMakeFiles/qgis_core.dir/diagram/qgspiediagram.cpp.o
src/core/CMakeFiles/qgis_core.dir/diagram/qgstextdiagram.cpp.o
src/core/CMakeFiles/qgis_core.dir/diagram/qgshistogramdiagram.cpp.o
src/core/CMakeFiles/qgis_core.dir/effects/qgsimageoperation.cpp.o
src/core/CMakeFiles/qgis_core.dir/effects/qgspainteffect.cpp.o
src/core/CMakeFiles/qgis_core.dir/effects/qgseffectstack.cpp.o
src/core/CMakeFiles/qgis_core.dir/effects/qgsblureffect.cpp.o
src/core/CMakeFiles/qgis_core.dir/effects/qgsshadoweffect.cpp.o
src/core/CMakeFiles/qgis_core.dir/effects/qgsgloweffect.cpp.o
src/core/CMakeFiles/qgis_core.dir/effects/qgspainteffectregistry.cpp.o
src/core/CMakeFiles/qgis_core.dir/effects/qgstransformeffect.cpp.o
src/core/CMakeFiles/qgis_core.dir/effects/qgscoloreffect.cpp.o
src/core/CMakeFiles/qgis_core.dir/layertree/qgslayertreegroup.cpp.o
src/core/CMakeFiles/qgis_core.dir/layertree/qgslayertreelayer.cpp.o
src/core/CMakeFiles/qgis_core.dir/layertree/qgslayertreemodel.cpp.o
src/core/CMakeFiles/qgis_core.dir/layertree/qgslayertreemodellegendnode.cpp.o
src/core/CMakeFiles/qgis_core.dir/layertree/qgslayertreenode.cpp.o
src/core/CMakeFiles/qgis_core.dir/layertree/qgslayertreeregistrybridge.cpp.o
src/core/CMakeFiles/qgis_core.dir/layertree/qgslayertreeutils.cpp.o
[ 4%] Building CXX object src/core/CMakeFiles/qgis_core.dir/qgis.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsapplication.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsattributeaction.cpp.o
/home/user/Code/QGIS/src/core/qgsattributeaction.cpp: In member function
‘bool QgsAttributeAction::readXML(const QDomNode&)’:
/home/user/Code/QGIS/src/core/qgsattributeaction.cpp:263: warning:
comparison between signed and unsigned integer expressions
[ 5%] Building CXX object
src/core/CMakeFiles/qgis_core.dir/qgsbrowsermodel.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgscachedfeatureiterator.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgscacheindex.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgscacheindexfeatureid.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsclipper.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgscolorscheme.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgscolorschemeregistry.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgscontexthelp.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgscontexthelp_texts.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgscoordinatereferencesystem.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgscoordinatetransform.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgscredentials.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsdartmeasurement.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgscrscache.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsdatadefined.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsdatasourceuri.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsdataitem.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsdataitemprovider.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsdataitemproviderregistry.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsdatumtransformstore.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsdbfilterproxymodel.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsdiagramrendererv2.cpp.o
/home/user/Code/QGIS/src/core/qgsdiagramrendererv2.cpp: In member
function ‘void QgsDiagramSettings::readXML(const QDomElement&, const
QgsVectorLayer*)’:
/home/user/Code/QGIS/src/core/qgsdiagramrendererv2.cpp:168: warning:
src/core/CMakeFiles/qgis_core.dir/qgsdistancearea.cpp.o
[ 5%] Building CXX object src/core/CMakeFiles/qgis_core.dir/qgserror.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsexpression.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsexpression_texts.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsexpressionfieldbuffer.cpp.o
/home/user/Code/QGIS/src/core/qgsexpressionfieldbuffer.cpp: In member
function ‘void QgsExpressionFieldBuffer::readXml(const QDomNode&)’:
/home/user/Code/QGIS/src/core/qgsexpressionfieldbuffer.cpp:72: warning:
src/core/CMakeFiles/qgis_core.dir/qgsfeature.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsfeatureiterator.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsfeaturerequest.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsfeaturestore.cpp.o
[ 5%] Building CXX object src/core/CMakeFiles/qgis_core.dir/qgsfield.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsfontutils.cpp.o
[ 6%] Building CXX object
src/core/CMakeFiles/qgis_core.dir/qgsgeometrycache.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsgeometrysimplifier.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsgeometryvalidator.cpp.o
[ 6%] Building CXX object src/core/CMakeFiles/qgis_core.dir/qgsgml.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsgmlschema.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgshistogram.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgslayerdefinition.cpp.o
[ 6%] Building CXX object src/core/CMakeFiles/qgis_core.dir/qgslabel.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgslabelattributes.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgslabelsearchtree.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgslegacyhelpers.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgslegendrenderer.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgslegendsettings.cpp.o
[ 6%] Building CXX object src/core/CMakeFiles/qgis_core.dir/qgslogger.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsmaphittest.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsmaplayer.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsmaplayerlegend.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsmaplayerregistry.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsmaplayerstylemanager.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsmaprenderer.cpp.o
/home/user/Code/QGIS/src/core/qgsmaprenderer.cpp: In member function
‘void QgsMapRenderer::adjustExtentToSize()’:
/home/user/Code/QGIS/src/core/qgsmaprenderer.cpp:229: warning: ‘void
QgsMapToPixel::setParameters(double, double, double, double)’ is
deprecated (declared at /home/user/Code/QGIS/src/core/qgsmaptopixel.h:199)
‘void QgsMapRenderer::render(QPainter*, double*)’:
/home/user/Code/QGIS/src/core/qgsmaprenderer.cpp:491: warning: ‘void
QgsMapToPixel::setYMaximum(double)’ is deprecated (declared at
/home/user/Code/QGIS/src/core/qgsmaptopixel.h:177)
‘void QgsMapRenderer::setProjectionsEnabled(bool)’:
/home/user/Code/QGIS/src/core/qgsmaprenderer.cpp:665: warning: ‘void
QgsMapRenderer::hasCrsTransformEnabled(bool)’ is deprecated (declared at
/home/user/Code/QGIS/src/core/qgsmaprenderer.h:344)
src/core/CMakeFiles/qgis_core.dir/qgsmaprenderercache.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsmaprenderercustompainterjob.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsmaprendererjob.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsmaprendererparalleljob.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsmaprenderersequentialjob.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsmapsettings.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsmaptopixel.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsmaptopixelgeometrysimplifier.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsmessagelog.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsmessageoutput.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsmimedatautils.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsmultirenderchecker.cpp.o
[ 7%] Building CXX object
src/core/CMakeFiles/qgis_core.dir/qgsnetworkaccessmanager.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsnetworkcontentfetcher.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsnetworkreplyparser.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsobjectcustomproperties.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsofflineediting.cpp.o
/home/user/Code/QGIS/src/core/qgsofflineediting.cpp: In member function
‘QgsVectorLayer* QgsOfflineEditing::copyVectorLayer(QgsVectorLayer*,
sqlite3*, const QString&)’:
/home/user/Code/QGIS/src/core/qgsofflineediting.cpp:565: warning: ‘bool
QgsVectorLayer::hasLabelsEnabled() const’ is deprecated (declared at
/home/user/Code/QGIS/src/core/qgsvectorlayer.h:1244)
src/core/CMakeFiles/qgis_core.dir/qgsogcutils.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsowsconnection.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgspaintenginehack.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgspallabeling.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgspluginlayer.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgspluginlayerregistry.cpp.o
[ 7%] Building CXX object src/core/CMakeFiles/qgis_core.dir/qgspoint.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgspointlocator.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsproject.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsprojectfiletransform.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsprojectproperty.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsprojectversion.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsprovidercountcalcevent.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsproviderextentcalcevent.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsprovidermetadata.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsproviderregistry.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgspythonrunner.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsrelation.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsrelationmanager.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsrenderchecker.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsrendercontext.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsrectangle.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsrunprocess.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsscalecalculator.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsscaleexpression.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsscaleutils.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgssimplifymethod.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgssnapper.cpp.o
[ 8%] Building CXX object
src/core/CMakeFiles/qgis_core.dir/qgssnappingutils.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsspatialindex.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsstatisticalsummary.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsstringutils.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgstransaction.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgstolerance.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsvectordataprovider.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsvectorfilewriter.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsvectorlayer.cpp.o
/home/user/Code/QGIS/src/core/qgsvectorlayer.cpp: In member function
‘virtual bool QgsVectorLayer::readSymbology(const QDomNode&, QString&)’:
/home/user/Code/QGIS/src/core/qgsvectorlayer.cpp:1604: warning: ‘void
QgsVectorLayer::enableLabels(bool)’ is deprecated (declared at
/home/user/Code/QGIS/src/core/qgsvectorlayer.cpp:1167)
/home/user/Code/QGIS/src/core/qgsvectorlayer.cpp:1608: warning: ‘void
‘virtual bool QgsVectorLayer::writeSymbology(QDomNode&, QDomDocument&,
QString&) const’:
/home/user/Code/QGIS/src/core/qgsvectorlayer.cpp:1863: warning: ‘bool
/home/user/Code/QGIS/src/core/qgsvectorlayer.cpp:1172)
‘QgsVectorLayer::EditType QgsVectorLayer::editType(int)’:
/home/user/Code/QGIS/src/core/qgsvectorlayer.cpp:2636: warning: ‘static
QgsVectorLayer::EditType QgsLegacyHelpers::convertEditType(const
QString&, const QgsEditorWidgetConfig&, QgsVectorLayer*, const
QString&)’ is deprecated (declared at
/home/user/Code/QGIS/src/core/qgslegacyhelpers.h:27)
‘void QgsVectorLayer::setEditType(int, QgsVectorLayer::EditType)’:
/home/user/Code/QGIS/src/core/qgsvectorlayer.cpp:2648: warning: ‘static
const QString
QgsLegacyHelpers::convertEditType(QgsVectorLayer::EditType,
QgsEditorWidgetConfig&, QgsVectorLayer*, const QString&, const
QDomElement&)’ is deprecated (declared at
/home/user/Code/QGIS/src/core/qgslegacyhelpers.h:26)
src/core/CMakeFiles/qgis_core.dir/qgsvectorlayercache.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsvectorlayereditbuffer.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsvectorlayereditpassthrough.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsvectorlayereditutils.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsvectorlayerfeatureiterator.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsvectorlayerimport.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsvectorlayerjoinbuffer.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsvectorlayerrenderer.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsvectorlayerundocommand.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsvectorsimplifymethod.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsxmlutils.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsslconnect.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgslocalec.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgsaddremoveitemcommand.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgsaddremovemultiframecommand.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposermultiframecommand.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerarrow.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerframe.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposermousehandles.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerobject.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerutils.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposeritem.cpp.o
/home/user/Code/QGIS/src/core/composer/qgscomposeritem.cpp: In member
function ‘bool QgsComposerItem::imageSizeConsideringRotation(double&,
double&) const’:
/home/user/Code/QGIS/src/core/composer/qgscomposeritem.cpp:1115:
warning: ‘bool QgsComposerItem::imageSizeConsideringRotation(double&,
double&, double) const’ is deprecated (declared at
/home/user/Code/QGIS/src/core/composer/qgscomposeritem.h:713)
double&, double) const’:
/home/user/Code/QGIS/src/core/composer/qgscomposeritem.cpp:1146:
warning: ‘bool
QgsComposerItem::cornerPointOnRotatedAndScaledRect(double&, double&,
double, double, double) const’ is deprecated (declared at
/home/user/Code/QGIS/src/core/composer/qgscomposeritem.h:732)
/home/user/Code/QGIS/src/core/composer/qgscomposeritem.cpp:1150:
warning: ‘bool
/home/user/Code/QGIS/src/core/composer/qgscomposeritem.cpp:1154:
warning: ‘bool
/home/user/Code/QGIS/src/core/composer/qgscomposeritem.cpp:1158:
warning: ‘bool
function ‘bool
double, double) const’:
/home/user/Code/QGIS/src/core/composer/qgscomposeritem.cpp:1194:
warning: ‘bool
function ‘void QgsComposerItem::sizeChangedByRotation(double&, double&)’:
/home/user/Code/QGIS/src/core/composer/qgscomposeritem.cpp:1239:
warning: ‘void QgsComposerItem::sizeChangedByRotation(double&, double&,
/home/user/Code/QGIS/src/core/composer/qgscomposeritem.h:742)
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposeritemcommand.cpp.o
[ 9%] Building CXX object
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposeritemgroup.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerlabel.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerlegenditem.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerpicture.cpp.o
/home/user/Code/QGIS/src/core/composer/qgscomposerpicture.cpp: In member
function ‘bool QgsComposerPicture::imageSizeConsideringRotation(double&,
double&) const’:
/home/user/Code/QGIS/src/core/composer/qgscomposerpicture.cpp:841:
function ‘bool
QgsComposerPicture::cornerPointOnRotatedAndScaledRect(double&, double&,
/home/user/Code/QGIS/src/core/composer/qgscomposerpicture.cpp:849:
warning: ‘bool
function ‘void QgsComposerPicture::sizeChangedByRotation(double&, double&)’:
/home/user/Code/QGIS/src/core/composer/qgscomposerpicture.cpp:857:
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposermap.cpp.o
/home/user/Code/QGIS/src/core/composer/qgscomposermap.cpp: In member
function ‘const QgsMapRenderer* QgsComposerMap::mapRenderer() const’:
/home/user/Code/QGIS/src/core/composer/qgscomposermap.cpp:518: warning:
‘QgsMapRenderer* QgsComposition::mapRenderer()’ is deprecated (declared
at /home/user/Code/QGIS/src/core/composer/qgscomposition.h:393)
function ‘bool QgsComposerMap::imageSizeConsideringRotation(double&,
double&) const’:
/home/user/Code/QGIS/src/core/composer/qgscomposermap.cpp:2342: warning:
‘bool QgsComposerItem::imageSizeConsideringRotation(double&, double&,
function ‘bool
QgsComposerMap::cornerPointOnRotatedAndScaledRect(double&, double&,
/home/user/Code/QGIS/src/core/composer/qgscomposermap.cpp:2350: warning:
‘bool QgsComposerItem::cornerPointOnRotatedAndScaledRect(double&,
double&, double, double, double) const’ is deprecated (declared at
function ‘void QgsComposerMap::sizeChangedByRotation(double&, double&)’:
/home/user/Code/QGIS/src/core/composer/qgscomposermap.cpp:2358: warning:
‘void QgsComposerItem::sizeChangedByRotation(double&, double&, double)’
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposermapitem.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposermapgrid.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposermapoverview.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposertable.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposertablev2.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposertablecolumn.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerattributetable.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerattributetablev2.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerattributetablemodel.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerattributetablemodelv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposertexttable.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerscalebar.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposershape.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposereffect.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgsatlascomposition.cpp.o
/home/user/Code/QGIS/src/core/composer/qgsatlascomposition.cpp: In
member function ‘bool QgsAtlasComposition::fixedScale() const’:
/home/user/Code/QGIS/src/core/composer/qgsatlascomposition.cpp:836:
warning: ‘QgsComposerMap* QgsAtlasComposition::composerMap() const’ is
/home/user/Code/QGIS/src/core/composer/qgsatlascomposition.cpp:116)
/home/user/Code/QGIS/src/core/composer/qgsatlascomposition.cpp:842:
warning: ‘bool QgsComposerMap::atlasFixedScale() const’ is deprecated
(declared at /home/user/Code/QGIS/src/core/composer/qgscomposermap.h:706)
member function ‘void QgsAtlasComposition::setFixedScale(bool)’:
/home/user/Code/QGIS/src/core/composer/qgsatlascomposition.cpp:848:
member function ‘float QgsAtlasComposition::margin() const’:
/home/user/Code/QGIS/src/core/composer/qgsatlascomposition.cpp:860:
member function ‘void QgsAtlasComposition::setMargin(float)’:
/home/user/Code/QGIS/src/core/composer/qgsatlascomposition.cpp:872:
src/core/CMakeFiles/qgis_core.dir/composer/qgslegendmodel.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerlegend.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerlegendstyle.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgspaperitem.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgsscalebarstyle.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgsdoubleboxscalebarstyle.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgsnumericscalebarstyle.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgssingleboxscalebarstyle.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgsticksscalebarstyle.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposerhtml.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposermultiframe.cpp.o
/home/user/Code/QGIS/src/core/composer/qgscomposermultiframe.cpp: In
member function ‘virtual void QgsComposerMultiFrame::render(QPainter*,
const QRectF&, int)’:
/home/user/Code/QGIS/src/core/composer/qgscomposermultiframe.cpp:56:
warning: ‘virtual void QgsComposerMultiFrame::render(QPainter*, const
QRectF&)’ is deprecated (declared at
/home/user/Code/QGIS/src/core/composer/qgscomposermultiframe.cpp:44)
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposermodel.cpp.o
[ 10%] Building CXX object
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposition.cpp.o
src/core/CMakeFiles/qgis_core.dir/dxf/qgsdxfexport.cpp.o
src/core/CMakeFiles/qgis_core.dir/dxf/qgsdxfpaintdevice.cpp.o
/home/user/Code/QGIS/src/core/dxf/qgsdxfpaintdevice.cpp: In member
function ‘virtual int
QgsDxfPaintDevice::metric(QPaintDevice::PaintDeviceMetric) const’:
/home/user/Code/QGIS/src/core/dxf/qgsdxfpaintdevice.cpp:37: warning:
enumeration value ‘PdmDevicePixelRatio’ not handled in switch
src/core/CMakeFiles/qgis_core.dir/dxf/qgsdxfpaintengine.cpp.o
src/core/CMakeFiles/qgis_core.dir/dxf/qgsdxfpallabeling.cpp.o
/home/user/Code/QGIS/src/core/dxf/qgsdxfpallabeling.cpp: In constructor
‘QgsDxfPalLabeling::QgsDxfPalLabeling(QgsDxfExport*, const
QgsRectangle&, double, QGis::UnitType)’:
/home/user/Code/QGIS/src/core/dxf/qgsdxfpallabeling.cpp:54: warning:
‘QgsMapToPixel::QgsMapToPixel(double, double, double, double)’ is
deprecated (declared at /home/user/Code/QGIS/src/core/qgsmaptopixel.h:45)
src/core/CMakeFiles/qgis_core.dir/pal/costcalculator.cpp.o
src/core/CMakeFiles/qgis_core.dir/pal/feature.cpp.o
src/core/CMakeFiles/qgis_core.dir/pal/geomfunction.cpp.o
src/core/CMakeFiles/qgis_core.dir/pal/labelposition.cpp.o
[ 10%] Building CXX object src/core/CMakeFiles/qgis_core.dir/pal/layer.cpp.o
[ 10%] Building CXX object src/core/CMakeFiles/qgis_core.dir/pal/pal.cpp.o
src/core/CMakeFiles/qgis_core.dir/pal/palstat.cpp.o
src/core/CMakeFiles/qgis_core.dir/pal/pointset.cpp.o
src/core/CMakeFiles/qgis_core.dir/pal/priorityqueue.cpp.o
src/core/CMakeFiles/qgis_core.dir/pal/problem.cpp.o
[ 10%] Building CXX object src/core/CMakeFiles/qgis_core.dir/pal/util.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgscliptominmaxenhancement.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsraster.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterblock.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgscolorrampshader.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgscontrastenhancement.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgscontrastenhancementfunction.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterdataprovider.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgslinearminmaxenhancement.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgslinearminmaxenhancementwithclip.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgspseudocolorshader.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterprojector.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterchecker.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsrasteridentifyresult.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterinterface.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsrasteriterator.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterlayer.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterlayerrenderer.cpp.o
[ 11%] Building CXX object
src/core/CMakeFiles/qgis_core.dir/raster/qgsrasternuller.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsrastertransparency.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterpipe.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterrange.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsrastershader.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsrastershaderfunction.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterdrawer.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterfilewriter.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterresamplefilter.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterrendererregistry.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsrasterrenderer.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsbilinearrasterresampler.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgscubicrasterresampler.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgspalettedrasterrenderer.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsmultibandcolorrenderer.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgssinglebandcolordatarenderer.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgssinglebandgrayrenderer.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgssinglebandpseudocolorrenderer.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgsbrightnesscontrastfilter.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/qgshuesaturationfilter.cpp.o
src/core/CMakeFiles/qgis_core.dir/geometry/qgsabstractgeometryv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/geometry/qgscircularstringv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/geometry/qgscompoundcurvev2.cpp.o
src/core/CMakeFiles/qgis_core.dir/geometry/qgscurvev2.cpp.o
src/core/CMakeFiles/qgis_core.dir/geometry/qgscurvepolygonv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/geometry/qgsgeometry.cpp.o
src/core/CMakeFiles/qgis_core.dir/geometry/qgsgeometrycollectionv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/geometry/qgsgeometryeditutils.cpp.o
src/core/CMakeFiles/qgis_core.dir/geometry/qgsgeometryfactory.cpp.o
src/core/CMakeFiles/qgis_core.dir/geometry/qgsgeometryutils.cpp.o
src/core/CMakeFiles/qgis_core.dir/geometry/qgsgeos.cpp.o
src/core/CMakeFiles/qgis_core.dir/geometry/qgspointv2.cpp.o
[ 12%] Building CXX object
src/core/CMakeFiles/qgis_core.dir/geometry/qgspolygonv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/geometry/qgslinestringv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/geometry/qgsmulticurvev2.cpp.o
src/core/CMakeFiles/qgis_core.dir/geometry/qgsmultilinestringv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/geometry/qgsmultipointv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/geometry/qgsmultipolygonv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/geometry/qgsmultisurfacev2.cpp.o
src/core/CMakeFiles/qgis_core.dir/geometry/qgswkbptr.cpp.o
src/core/CMakeFiles/qgis_core.dir/geometry/qgswkbtypes.cpp.o
src/core/CMakeFiles/qgis_core.dir/gps/qextserialport/qextserialport.cpp.o
src/core/CMakeFiles/qgis_core.dir/gps/qextserialport/qextserialenumerator.cpp.o
src/core/CMakeFiles/qgis_core.dir/gps/qextserialport/posix_qextserialport.cpp.o
src/core/CMakeFiles/qgis_core.dir/gps/qgsqtlocationconnection.cpp.o
/home/user/Code/QGIS/src/core/gps/qgsqtlocationconnection.cpp: In member
function ‘virtual void QgsQtLocationConnection::parseData()’:
/home/user/Code/QGIS/src/core/gps/qgsqtlocationconnection.cpp:87:
warning: statement has no effect
/home/user/Code/QGIS/src/core/gps/qgsqtlocationconnection.cpp:88:
/home/user/Code/QGIS/src/core/gps/qgsqtlocationconnection.cpp:89:
/home/user/Code/QGIS/src/core/gps/qgsqtlocationconnection.cpp:91:
/home/user/Code/QGIS/src/core/gps/qgsqtlocationconnection.cpp:92:
/home/user/Code/QGIS/src/core/gps/qgsqtlocationconnection.cpp:93:
src/core/CMakeFiles/qgis_core.dir/flex_qgsexpressionlexer.cpp.o
src/core/CMakeFiles/qgis_core.dir/qgsexpressionparser.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsapplication.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsbrowsermodel.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgscontexthelp.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgscoordinatetransform.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsdataitem.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsdataprovider.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsgml.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsgmlschema.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsmaplayer.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsmaplayerlegend.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsmaplayerregistry.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsmaplayerstylemanager.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsmaprenderer.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsmaprenderercache.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsmaprenderercustompainterjob.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsmaprendererjob.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsmaprendererparalleljob.cpp.o
[ 13%] Building CXX object
src/core/CMakeFiles/qgis_core.dir/moc_qgsmaprenderersequentialjob.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsmessageoutput.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsmessagelog.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsnetworkreplyparser.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsnetworkcontentfetcher.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsofflineediting.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgscredentials.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgspluginlayer.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgspointlocator.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsproject.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsrunprocess.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsrelationmanager.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgssnappingutils.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsvectorlayer.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsvectorlayereditpassthrough.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsvectorlayereditbuffer.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsnetworkaccessmanager.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsvectordataprovider.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsvectorlayercache.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsvectorlayerjoinbuffer.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgsgeometryvalidator.cpp.o
src/core/CMakeFiles/qgis_core.dir/moc_qgswebview.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgsaddremoveitemcommand.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposerlegend.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposermap.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposermapitem.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposermapgrid.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposermapoverview.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposerpicture.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposerscalebar.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposerobject.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposeritem.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposeritemgroup.cpp.o
[ 14%] Building CXX object
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposermousehandles.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposerlabel.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposershape.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposerattributetable.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposerattributetablev2.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposerattributetablemodel.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposerattributetablemodelv2.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposertable.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposertablev2.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposertablecolumn.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposertexttable.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposerhtml.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposermultiframe.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposereffect.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgsatlascomposition.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposermodel.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgscomposition.cpp.o
src/core/CMakeFiles/qgis_core.dir/composer/moc_qgslegendmodel.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/moc_qgsrasterlayer.cpp.o
src/core/CMakeFiles/qgis_core.dir/raster/moc_qgsrasterdataprovider.cpp.o
src/core/CMakeFiles/qgis_core.dir/gps/moc_qgsgpsconnection.cpp.o
src/core/CMakeFiles/qgis_core.dir/gps/moc_qgsgpsdetector.cpp.o
src/core/CMakeFiles/qgis_core.dir/gps/moc_qgsnmeaconnection.cpp.o
src/core/CMakeFiles/qgis_core.dir/gps/moc_qgsgpsdconnection.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/moc_qgscptcityarchive.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/moc_qgssvgcache.cpp.o
src/core/CMakeFiles/qgis_core.dir/symbology-ng/moc_qgsstylev2.cpp.o
src/core/CMakeFiles/qgis_core.dir/layertree/moc_qgslayertreegroup.cpp.o
src/core/CMakeFiles/qgis_core.dir/layertree/moc_qgslayertreelayer.cpp.o
src/core/CMakeFiles/qgis_core.dir/layertree/moc_qgslayertreemodel.cpp.o
src/core/CMakeFiles/qgis_core.dir/layertree/moc_qgslayertreemodellegendnode.cpp.o
src/core/CMakeFiles/qgis_core.dir/layertree/moc_qgslayertreenode.cpp.o
[ 15%] Building CXX object
src/core/CMakeFiles/qgis_core.dir/layertree/moc_qgslayertreeregistrybridge.cpp.o
src/core/CMakeFiles/qgis_core.dir/gps/qextserialport/moc_qextserialport.cpp.o
src/core/CMakeFiles/qgis_core.dir/gps/qextserialport/moc_qextserialenumerator.cpp.o
src/core/CMakeFiles/qgis_core.dir/gps/moc_qgsqtlocationconnection.cpp.o
Linking CXX shared library ../../output/lib/libqgis_core.so
CMakeFiles/qgis_core.dir/composer/qgscomposerlabel.cpp.o: In function
`QgsComposerLabel::paint(QPainter*, QStyleOptionGraphicsItem const*,
QWidget*)':
qgscomposerlabel.cpp:(.text+0xe79): undefined reference to
`QWebFrame::render(QPainter*)'
CMakeFiles/qgis_core.dir/composer/qgscomposerhtml.cpp.o: In function
`QgsComposerHtml::renderCachedImage()':
qgscomposerhtml.cpp:(.text+0x153f): undefined reference to
collect2: ld returned 1 exit status
make[2]: *** [output/lib/libqgis_core.so.2.11.0] Error 1
make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
make: *** [all] Error 2
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150630/bd8698df/attachment.sig>
