[Qgis-user] Opengeo Explorer
    Victor Olaya
    volayaf at gmail.com
    Wed Mar 11 00:52:07 PDT 2015
If you want to use the plugin, better get it from the Boundless plugin repo
If you use the github version, you have to fetch the dependencies
first and then install.
You need paver to do it. Once you have paver installed, do
$ paver setup
$ paver install
in the plugin folder
Then you can open QGIS and the plugin should be there already available.
As I say, better install using the plugin manager and the Boundless
plugin repo version.
If you are only interested in working with GeoServer, we are about to
release a new plugin that only has the GeoServer elements. That will
probably be released in the usual plugin repo, but we are still
working on it.
Cheers
2015-03-11 7:36 GMT+01:00 Mats Elfström <mats.elfstrom at gmail.com>:
> What is the word on Opengeo Explorer and QGIS 2.8.1? I am on Windows
> server 2012 64 bit and pulled the plugin from Github. On a standalone
> QGIS 64 bit the plugin fails to start. I can post the error litany but
> it is maybe known that the plugin is broken. What other ways are there
> to publish to Geoserver?
> Hälsning / Regards
> Mats.E
> Skickat från min / Sent from my iPhone, Ursäkta att jag är kortfattad
> / Excuse my brevity.
> Qgis-user mailing list
