[Qgis-user] Panasonic Toughbook FZ-G1 and QGIS
Stéphane Henriod
s at henriod.info
Wed Mar 18 07:52:03 PDT 2015
Hi
We have been using the FZ-G1 in the field with Win 8 and we were pretty
happy with it (not with Qgis though).
The only down we have identified until now is that the port on which the
GPS is running (COM3 if I remember correctly) sometimes switches off
without any reason... Given that the people who use it in the field are not
always super techy, it can be an issue to switch the port on again...
But we haven't been able to identify in which situation this "bug" (or
whatever that is) happens.
Hope that helps
Stéphane
"Le mot progrès n'aura aucun sens tant qu'il y aura des enfants malheureux"
-- Albert Einstein
"Si les contacts avec les étrangers lui étaient permis, [le citoyen
ordinaire] découvrirait que ce sont des créatures semblables à lui-même et
que la plus grande partie de ce qu'on lui a raconté d'eux est fausse. Le
monde fermé, scellé, dans lequel il vit, serait brisé, et la crainte, la
haine, la certitude de son bon droit, desquelles dépend sa morale,
pourraient disparaître" -- George Orwell ("1984")
“When you travel, remember that a foreign country is not designed to make
you comfortable. It is designed to make its own people comfortable." --
Clifton Fadiman
Photos de voyages, photos de montagne: http://www.henriod.info
2015-03-11 6:41 GMT+01:00 Bo Victor Thomsen <bo.victor.thomsen at gmail.com>:
> I don't have any experience with the FZ-G1, only some older Toughbook
> models. You can't kill them even if you drove over them with a truck :-)
> Anyway, the agency I assist with their Tablet based field solution, is
> now using relatively cheap consumer tablets together with external USB
> based GNNS recievers.
> Just keep your option open about the GPS. The market for cheap GPS'es is
> moving very fast, so any built-in GPS will like be outmoded long before the
> rest of the pc is. Keep your options open so it's possible to use a cheap
> and simple external GPS (USB or Bluetooth based).
> The GPS I'm using and recommending right now is a HOLUX M215+ (Remember
> the "+") which is a combined GPS/GLONASS receiver. It consistently finds
> around 20 satellites (under a clear sky), has a PDOP under 1.0 and is very
> stable
> If you need centimeter or decimeter precision, you're probably better of
> by buying a dedicated professional GNNS reciever in quite another
> price-range
> Regards
> Bo Victor Thomsen
> AestasGIS
> Denmark
> Den 09-03-2015 kl. 10:05 skrev Otto Dassau:
>> Hi,
>> does anybody have experience with the Panasonic Toughbook FZ-G1 (with
>> Windows
>> 8.1 or 7 professional) and QGIS for field work? Especially working with
>> the onboard GPS chip is interesting. Does it work without problems?
>> Regards,
>> Otto
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150318/209223a6/attachment.html>
