[Qgis-user] OSM and postgres speed
Thomas Endres endres.thomas at gmail.com
Thu Nov 5 09:50:48 PST 2015
Hi Ross - thanks for your suggestions. See notes below.
* all installed on the same machine? How many cores? 64bit?
Yes - all on same machine - 4 cores - 64 bit
> * are you trying to route across your network or just draw the features?
* if you are routing you can try using a bounding box on your query to
> limit the number of features returned.
No routing - just drawing.
> * have you run a full vacuum analyse on your Postgres tables to update
> statistics?  How many features in your tables?
Yes and repeated just to make sure - no difference.
> * try resetting your PostGIS connection in QGIS to not use the estimate
> extent.
Where is this setting in QGIS?
> * spatial and attribute indexes on relevant fields in the table?
Yes
> * in QGIS you can set, under Settings > Options > Rendering, to render
> layers in parallel and also set the number of cores to use.
Already set to render layers in parallel and using all 4 cores.
> * can you set some scale dependent rendering on your layer so that it only
> draws some features at small scales and then more detail as you zoom in?
I hope to when I can get that far. Are you using North America OSM data
without issues?
Wishing I could see why QGIS is taking up so much CPU for so long w/PostGIS
when trying to load a project.
Strange behavior - looking for any tools to troubleshoot and provide more
information.
Thanks again,
-tom
> On 03/11/15 19:24, Thomas Endres wrote:
> Hi Everyone,
> Running QGIS 2.12.0, Postgres 9.4.4, and PostGIS 2.1.7 on Ubuntu 14.04
> with 16 gig RAM.
> With North America OSM data loaded into postgres via osm2pgsql I am having
> some extremely long project load times, even with only a single simple
> layer enabled.
> Progress bar runs for a very long time with no apparent visible changes.
> Indexes and configuration on the db side looks good.
> Wondering how to diagnose extremely slow rendering times from a local
> postgres instance? Do I need to build from scratch to enable logs?
> While trying to monitor the server I noticed the following:
> - a few processes running SELECT st_estimatedextent....
> - a few processes running FETCH FORWARD 2000 FROM...
> Thanks in advance for any pointers.
> -tom
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151105/fd5bba6e/attachment.html>
