[Qgis-user] Importing image to Print Composer
Neumann, Andreas
a.neumann at carto.net
Thu Nov 12 08:41:45 PST 2015
You can use visibility presets (bookmarks of layer visibilities) and
activate "Lock layer" checkbox with a visibility preset combination.
Each map can have a different layer combination.
See manual for more instructions.
Andreas
On 2015-11-12 17:28, simonc8 wrote:
> Hi
> Thanks for pointing me at this. I've managed to create an index map within
> the same project and create the overview outline of the main map.
> However, the index map has a completely different set of layers to the main
> map. Is there a way of organising the layers into groups so I could quickly
> turn off all the main map layers and turn on all the index map layers (and
> vice versa)?
> Thanks
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Importing-image-to-Print-Composer-tp5235991p5236019.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151112/811fb2b7/attachment.html>
