[Qgis-user] Geoserver WFS update request error
aperi2007
aperi2007 at gmail.com
Mon Nov 30 10:12:11 PST 2015
AFAIK the writing of an uri in an xmlns is generally allowed.
http://www.w3schools.com/xml/xml_namespaces.asp
>When using prefixes in XML, a *namespace* for the prefix must be defined.
>The namespace can be defined by an *xmlns* attribute in the start tag
of an element.
>The namespace declaration has the following syntax.
xmlns:/prefix/="/URI/".
Regards,
A.
Il 28/11/2015 09:34, Richard Duivenvoorde ha scritto:
> 2 options:
> - xml guru confirms that it is not ok to write a uri in a xmlns attribute
> - if you are able to compile yourself, you could try to change #53 to
> change to 'wfs' instead of the uri, and check if all requests are still
> valid...
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151130/d83f697f/attachment.html>
