[Qgis-user] repeat image on every page in print composer
    Joris Hintjens
    jorishin at gmail.com
    Mon Oct 19 12:43:56 PDT 2015
Hello Andreas, thanks for your comment.
actually, I am working on a large report where I will have to make several pages (+/- 10: a page for each layer in my project) and multiply them again with the atlas generator. (times 50!) I hope it will work out …
I found your work-around this afternoon, studying basic HTML since supper  now…
Joris
> Op 19-okt.-2015, om 21:30 heeft Andreas Neumann <a.neumann at carto.net> het volgende geschreven:
> Hi Joris,
> Currently, only the HTML item has a "Repeat on every page" option. So - as your workaround you could write a very small HTML, which references an image.
> I agree, an option to repeat an item on every page would be useful for any element - e.g. labels, image, etc.
> If you talk about Atlas context - of course all the elements in the Atlas template would repeat on every page ...
> Andreas
> On 19.10.2015 21:07, Joris Hintjens wrote:
>> Hi,
>> I am looking fo a way to repeat a logo on every page in a multi-page print layout (that is: another way than repeating the layout manually for every page). No info on the tutorials and mailing list archive found. Thanks for any comment
>> Joris
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
