[Qgis-user] repeat image on every page in print composer
Andreas Neumann
a.neumann at carto.net
Tue Oct 20 00:27:05 PDT 2015
Hi Joris,
Actually there are plans to create a report generator in one of the
upcoming QGIS versions. Nyall Dawson works on this.
But the ability to repeat an item on every page could go into QGIS
before that - e.g. the next version. It could go into the general
"Rendering properties" of a print composer item.
You can ask Nyall Dawson about a quote - if you need this.
Andreas
On 19.10.2015 21:43, Joris Hintjens wrote:
> Hello Andreas, thanks for your comment.
> actually, I am working on a large report where I will have to make several pages (+/- 10: a page for each layer in my project) and multiply them again with the atlas generator. (times 50!) I hope it will work out …
> I found your work-around this afternoon, studying basic HTML since supper now…
> Joris
>> Op 19-okt.-2015, om 21:30 heeft Andreas Neumann <a.neumann at carto.net> het volgende geschreven:
>> Hi Joris,
>> Currently, only the HTML item has a "Repeat on every page" option. So - as your workaround you could write a very small HTML, which references an image.
>> I agree, an option to repeat an item on every page would be useful for any element - e.g. labels, image, etc.
>> If you talk about Atlas context - of course all the elements in the Atlas template would repeat on every page ...
>> Andreas
>> On 19.10.2015 21:07, Joris Hintjens wrote:
>>> Hi,
>>> I am looking fo a way to repeat a logo on every page in a multi-page print layout (that is: another way than repeating the layout manually for every page). No info on the tutorials and mailing list archive found. Thanks for any comment
>>> Joris
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
