[Qgis-user] RES: Set default view for Identify window?
jhcarneiro at axaeng.com
Tue Oct 20 06:17:43 PDT 2015
Good solution. One thing I noticed though is that the action isn't immediately visible in the identify window. This may have to do with the tree mode. Any way to configure so that actions are always on a zero node of the tree?
Best regards,
João Carneiro
Enviado pelo aplicativo myMail para Android
terça-feira, 20 outubro 2015, 11:03AM -02:00 de Richard McDonnell <richard.mcdonnell at opw.ie>:
This is possible if you use Actions in the Styling
Here is an example of one I prepared to open DXF's from within QGIS
(see image below)
[% "LOCATION" %]/[% "FORMAT" %]/[% "SCALE" %]/full/[% "MAP_NUMBER"
%].[% "FORMAT" %]
The Data is a Vector Tile Index for OSi DXF maps for the entire
country (Ireland), I use multiple fields to create the file
extension, as it easily allows me to edit the "LOCATION" Field, to
change drive locations for other departments. The values in the ""
are the Column Headers, so I have:
* "LOCATION" Root Folder Location (Eg...C:/Osi_Maps)
* "FORMAT" Data supplied in DXF and NTF (eg....DXF)
* "SCALE" 1:1000, 2500 & 5000 (eg.....1000)
* "MAP_NUMBER" OSi Index Number
* "FORMAT" again
The above string then constructs the Path to the Vector resulting
in for example
C:/Osi_Maps/DXF/1000/full/1000_a.dxf
Clear as Mud eh!!!
Regards,
Richard McDonnell
On 20/10/2015 12:42, João Carneiro
wrote:
>Hello all,
>Taking advantage of this topic to request
something that would really help me out in my projects, and
probably others as well. Would it be possible to text fields
automatically if they are valid paths to files when
identifying? If so, make it a link that opens the default
program that can handle that file?
>Best regards,
>João Carneiro
>De: Qgis-user [ mailto:qgis-user-bounces at lists.osgeo.org ] Em
nome de Richard McDonnell
>Enviada em: terça-feira, 20 de outubro de 2015
09:33
>Para: qgis-user at lists.osgeo.org
>Assunto: Re: [Qgis-user] Set default view for
Identify window?
>I do like the
pop up window, but the problem with is that it disappears to
the back, when you go to pan or zoom out, the option to have
it auto close would be nice, also to have them stay on top
until you close them or pan/zoom, this could allow you to
select one or two entity's for comparison or editing for
example. Upon panning or zooming they both close...does that
make sense?
>Actually I am thinking along the lines of something like the
Attribute table, but where you filter by selection!
>Regards,
>Richard McDonnell
>On 20/10/2015 12:14, Nathan Woodrow
wrote:
>>I'm keen to kill that dock and replace
it with something better in the next version or version
after. Open to ideas on that.
>>Regards,
>>Nathan
>>On Tue, Oct 20, 2015 at 9:05 PM,
Richard Duivenvoorde < rdmailings at duif.net >
wrote:
>>On 20-10-15 12:46, DelazJ wrote:
>>> Confirmed while testing on a raster: the three view
options remain
>>> available.
>>> Maybe time has come to see how they can be improved
and set availbale
>>> for vector layers :)
>>Ah, now I understand. So they should NOT be usable with
vector layers,
>>but only when you have rasters??
>>Because sometimes they are enabled with me, when I had a
vector layer
>>loaded...
>>Little messy ui behaviour :-(
>>Regards,
>>Richard
>>_______________________________________________
>>Qgis-user mailing list
>>Qgis-user at lists.osgeo.org
>>http://lists.osgeo.org/mailman/listinfo/qgis-user
>OPW
- Ag féachaint don am atá le teacht - Ag caomhnú ón am atá
thart
>OPW - Looking to the future - Caring for the past
>Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151020/988ae620/attachment.html>
