[Qgis-user] QGIS 2.12 Node editing very laggy with snapping enabled
Martin Bain
Martin.Bain at lismore.nsw.gov.au
Wed Oct 28 17:25:43 PDT 2015
Has anyone else found editing object vertices with the node tool in 2.12 to be very laggy?
For me it doesn't update the screen in real time, if I move the node to a new location I get no visual feedback until after a couple of seconds when node abruptly appears in the new location. It is smooth when snapping is "off" but with the same snapping settings as in 2.10 (all layers, vertex only, no topological, no snap on intersection) it is unusably slow.
This email is intended for the named recipient only. The information it contains may be confidential. If you are not the intended recipient you must not reproduce or distribute any part of this email, disclose its contents to any other party or take any action in reliance on it. If you have received this email in error, please contact the sender immediately and delete the message.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151029/408fb131/attachment.html>
