[Qgis-user] Scale behaviour
Andreas Neumann
a.neumann at carto.net
Wed Sep 16 06:39:26 PDT 2015
Hi Felix,
Can you please check if you have the Tile Map Scale Plugin active? This
plugin forces QGIS into these "unround" values which correspond to tile
map zoom levels.
I remember other users ran into this issue in the past.
Andreas
On 16.09.2015 15:01, reichert wrote:
> Hello,
> when I'm selecting a scale of the scale selection list it's always
> represented in an scale "nearby" the selected value (1:22.569 instead
> of 1:25.000, 1:11.284 instead 1:10.000, 1:5.642 instead of 1:5000).
> SRS/KBS is preselected on EPSG 31467, and units as 'Meter'. Alle
> physical layers are projected in 31467, severeal wms are in wgs
> 84/EPSG 3857. Projection on the fly is activated to 31467
> What else must be configured to obtain the selected scale exactly?
> Qgis 2.8.1
> Thanks in advance
> Felix
