[Qgis-user] qgis server - line symbology
    Andreas Neumann
    a.neumann at carto.net
    Mon Sep 21 05:04:34 PDT 2015
Hi Markus,
There is no other solution to your problem, other than upgrading your
QGIS server. Unless you would yourself invest into scripting and
comparing .qgs changes. And I guess this would be much more work than
upgrading your QGIS server software.
Andreas
On 19.09.2015 16:34, Markus Weidenbach wrote:
> Hi Mark,
> I have exactly the same problem.
> I installed the QGIS Server 2.2 (valmiera) on my remote Linux/Debian
> server and as long as I was feeding it with Projectfiles made with
> QGIS Valmiera 2.2 all worked fine, but since I upgraded my Desktop
> QGIS to 2.8.2, I have the same problem with the vector and polygon
> outlines, which all appear black.
> So, obviously the older QGIS server cannot handle the symbology
> settings of the newer xml project files produced with QGIS 2.8.
> Did you, or anybody else on the list,  know a workaround other than
> updating the older QGIS server (which could be a tricky work ....)?
> Markus *
> *Am 15.04.2015 00:24, schrieb Mark Seibel:
>> I'm using Qgis Desktop 2.6, and when I move the files to the qgis web
>> server, the symbology for lines as well as polygon outlines do not
>> get rendered any other way than a black line. Points and polygon
>> fills (solid and hatching) symbolize correctly in qgis server.
>> I have done this before and had it working, but perhaps under a
>> different version.  The underlying vector data is shapefiles.
>> Any suggestions?
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150921/33f3384e/attachment.html>
