[Qgis-user] QGIS big fail in deleting Shapes!!
Dietrich Heintz
dheintz at gmx.net
Tue Jan 19 23:16:08 PST 2016
Dear Uwe,
shape-file format is a proprietary format and we sometimes observe that
huge shape-files perform better (faster) in ESRI software.
I work a lot with shape-files, but the problem you describe I never had.
If you have ArcGIS license you can manipulate the shape-file there. If
you don't have you will do it in QGIS or any other open-source GIS software.
That is all to say about competition. If you had a version of ArcView
you might have detected even more problems when working with huge
shape-files, although it always was very fast.
ciao Dieter
On 19.01.2016 20:09, Uwe Fischer wrote:
> Hello all,
> today I was working on a shape dataset and I had to delete some
> features. Later I opened the shapefile in ArcMap by chance and I found
> that the features were not deleted. They still did exist. I repeated
> the process – and got the same result. Then, searching the internet, I
> found this incredible post: https://hub.qgis.org/issues/11007
> It is a well known problem (for 1,5 years!!) that /_QGIS is not able
> to delete shapes in a reliable way_/!! I was horrified to read this
> because it is the same as if a Word processor would not be able to
> delete a letter from a text. I cannot understand why the QGIS
> developers haven’t fix that yet. If QGIS really wants to compete with
> ArcMap, they should fix it as soon as possible. At least, the
> according menu entries or buttons should be inactivated if they don’t
> bring out reliable results.
> My questions are:
> ·is this information still up to date? I can‘t read all of the 80
> answers to the post now to get in-depth information ...
> ·does anybody have information about how they are planning to handle
> this problem at the development team?
> ·is there a workaround for this? Do the GRASS vector tools bring out
> reliable results?
> ·are there more of those software errors in QGIS that might lead to
> huge problems in working on vector data and sharing them with others?
> If so, is there a „black list“ of things one is never allowed to use
> in QGIS if you don’t want to destroy your datasets?
> Regards,
> Uwe Fischer
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160120/8091e3b6/attachment.html>
