[Qgis-user] crash loading missing wfs connection
emmexx emmexx at tiscalinet.it
Sat Jan 23 06:45:59 PST 2016
Il 01/23/2016 01:00 PM, Richard Duivenvoorde scrisse:
> Yes you can delete the 'connections-wfs' lines, then these saved
> connection will be gone.
Connections deleted and qgis starts.
> I 'think' however, that it will still be around in your project file
> (though you can edit that one too... to remove it).
My file has the right connection.
> But as Matthias says: it would be good to see if it occurs in newer
> versions too, because then.... it's a bug
I'll try. Slackware packages are updated not very frequently.
> So is it a special/public wfs, can you give the connection url?
> Or is it a local one, which you run yourself?
You don't need a specific connection. You can just add a non existent
connection to your QGIS2.conf file.
My problem surfaced when I temporarily disabled the production geoserver
to run a test. I installed on the server a different geoserver version
in a different folder. I connected QGIS to this server, run the test and
enabled the production server.
The production server url was:
http://publicip:8080/geoserver/wfs
The test server:
http://publicip:8080/gs281/wfs
Qgis started to crash after deleting the test server.
I'll report on other qgis versions as soon as I can.
thank you
	maxx
