[Qgis-user] Qgis-user Digest, Vol 119, Issue 50
    Eddison Araya
    eddisonjose at gmail.com
    Thu Jan 28 05:39:35 PST 2016
Hola, muchas gracias, voy a revisar sus amables respuestas.
Saludos
Eddison
2016-01-28 3:43 GMT-06:00 <qgis-user-request at lists.osgeo.org>:
> Send Qgis-user mailing list submissions to
>         qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         http://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>    1. Re: Como eliminar gaps en SRTM 30 metros (Nicolas Cadieux)
>    2. Re: Como eliminar gaps en SRTM 30 metros (Nicolas Cadieux)
>    3. Re: Eliminate GAPS SRTM 30 metros (Nicolas Cadieux)
>    4. Re: Eliminate GAPS SRTM 30 metros (Nicolas Cadieux)
>    5. Re: Eliminate GAPS SRTM 30 metros (Nicolas Cadieux)
>    6. Re: Qgis-user Digest, Vol 119, Issue 49 (Eddison Araya)
>    7. Re: Eliminate GAPS SRTM 30 metros (Thomas Götzelt)
>    8. Re: Including Images in Print Composer Templates
>       (Bernhard Ströbl)
> Message: 1
> Date: Wed, 27 Jan 2016 12:26:59 -0800 (PST)
> From: Nicolas Cadieux <nicolas.cadieux at archeotec.ca>
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Como eliminar gaps en SRTM 30 metros
> Message-ID: <f301d01a-11bf-4870-a44e-1ac72783d847 at email.android.com>
> Content-Type: text/plain; charset="utf-8"
> Holà,
> Utilisa la version 3 o mejor, la version srtmgl1.  No hay gaps.
> Nicolas Cadieux M.Sc.
> Les Entreprises Archéotec inc.
> 8548, rue Saint-Denis Montréal H2P 2H2
> Téléphone: 514.381.5112  Fax: 514.381.4995
> www.archeotec.ca
> On Jan 27, 2016 1:00 PM, "Eddison [via OSGeo.org]" &
> lt;ml-node+s1560n5247651h42 at n6.nabble.com> wrote:
>         Hola tengo un SRTM pero al abrirlo en QGIS veo que tiene zonas sin
> datos (gaps), como puedo solucionar ese problema para poder realizar
> procesos peosteriores? Gracias Eddison
> [hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe:
>                 If you reply to this email, your message will be added to
> the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Como-eliminar-gaps-en-SRTM-30-metros-tp5247651.html
>                 To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38@n6.nabble.com
>                 To unsubscribe from Quantum GIS - User, click here .
>                 NAML
> http://osgeo-org.1560.x6.nabble.com/Como-eliminar-gaps-en-SRTM-30-metros-tp5247651p5247671.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20160127/59c0dcf7/attachment-0002.html
> Message: 2
> Holà,
> www.archeotec.ca
> [hidden email]
>                 NAML
> http://osgeo-org.1560.x6.nabble.com/Como-eliminar-gaps-en-SRTM-30-metros-tp5247651p5247672.html
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20160127/59c0dcf7/attachment-0003.html
> Message: 3
> Date: Wed, 27 Jan 2016 12:33:16 -0800 (PST)
> Subject: Re: [Qgis-user] Eliminate GAPS SRTM 30 metros
> Message-ID: <5269b87e-5c61-464e-a94b-12c5352e9c07 at email.android.com>
> Hi
> Srtm have many versions with two pixel sizes.  30 m and 90m (at the
> equator). Version has gaps, version two has gap filling for water and small
> hole and version 3 has gap replacement in larger areas.  Gaps are
> caused by radar shadows.  Big gaps are filled using secondary
> dems.  The are all downloadable for free. The latest version in
> srtmGL1 of the 30m pixels.  NASA is currently working on a new version
> called NASA dems.  If the are existent for your region, use those.
> www.archeotec.ca
> On Jan 27, 2016 1:14 PM, "Eddison [via OSGeo.org]" &
> lt;ml-node+s1560n5247652h73 at n6.nabble.com> wrote:
>         Hola, how eliminate gaps in SRTM 30 meters?, in QGIS see no data
> areas (gaps). Thank you
> [hidden email]
> http://osgeo-org.1560.x6.nabble.com/Eliminate-GAPS-SRTM-30-metros-tp5247652.html
>                 NAML
> http://osgeo-org.1560.x6.nabble.com/Eliminate-GAPS-SRTM-30-metros-tp5247652p5247673.html
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20160127/e98998f0/attachment-0001.html
> Message: 4
> Date: Wed, 27 Jan 2016 12:35:37 -0800 (PST)
> Message-ID: <7cda64f9-7996-4fbb-bd1d-eb7830539a6e at email.android.com>
> Hi,
> Aster gdem are not as good with about 7 m error. They are clearly canopy
> level models.  They cover up to 83d and srtm are south and north of
> 60d only.  They are more detailed.
> www.archeotec.ca
> On Jan 27, 2016 2:38 PM, "Carlos Cerdán [via OSGeo.org]    " &
> lt;ml-node+s1560n5247658h59 at n6.nabble.com> wrote: Hi Eddison: Try
> r.fillnulls from Processing or directly in GRASS. So, we have 30 m SRTMS in
> http://www2.jpl.nasa.gov/srtm/  . It'll be interesting to compare
> with ASTER GDEM Cheers 2016-01-27 13:25 GMT-05:00 Eddison Araya <
> [hidden email] >: <blockquote style="border-left:2px solid
> #cccccc;padding:0 1em" style="margin:0 0 0 0.8ex;border-left:1px
> #ccc solid;padding-left:1ex"> Hola, how eliminate gaps in SRTM 30
> meters?, in QGIS see no data areas (gaps). Thank you
> [hidden email]
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> [hidden email]
> http://osgeo-org.1560.x6.nabble.com/Eliminate-GAPS-SRTM-30-metros-tp5247652p5247658.html
>                 NAML
> http://osgeo-org.1560.x6.nabble.com/Eliminate-GAPS-SRTM-30-metros-tp5247652p5247675.html
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20160127/0b7f6ee9/attachment-0002.html
> Message: 5
> Hi,
> www.archeotec.ca
> [hidden email]
> [hidden email]
>                 NAML
> http://osgeo-org.1560.x6.nabble.com/Eliminate-GAPS-SRTM-30-metros-tp5247652p5247674.html
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20160127/0b7f6ee9/attachment-0003.html
> Message: 6
> Date: Wed, 27 Jan 2016 19:06:12 -0600
> From: Eddison Araya <eddisonjose at gmail.com>
> To: qgis-user <qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] Qgis-user Digest, Vol 119, Issue 49
> Message-ID:
>         <CAC-LqCmY9NyPwdyAJswn=
> 7OpVtwZLsWPeH3qMuvotbOrGmoYkA at mail.gmail.com>
> Hola muchas gracias, voy a revisar el comando y les informo, gracias!
> > Today's Topics:
> >    1. Re: Eliminate GAPS SRTM 30 metros (Carlos Cerdán)
> > Message: 1
> > Date: Wed, 27 Jan 2016 14:49:25 -0500
> > From: Carlos Cerdán <sig.upagu at gmail.com>
> > Message-ID:
> >         <CAFvg7Wi0vVh2ouU78=_
> > xP6BNsN8XYGEtvJn5xd80dkLNR5avNw at mail.gmail.com>
> > Hi Eddison:
> > Try r.fillnulls from Processing or directly in GRASS.
> > So, we have 30 m SRTMS in http://www2.jpl.nasa.gov/srtm/ . It'll be
> > interesting to compare with ASTER GDEM
> > Cheers
> > 2016-01-27 13:25 GMT-05:00 Eddison Araya <eddisonjose at gmail.com>:
> > > Hola, how eliminate gaps in SRTM 30 meters?, in QGIS see no data areas
> > > (gaps). Thank you
> > > _______________________________________________
> > > Qgis-user at lists.osgeo.org
> > URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20160127/a044bb6d/attachment-0001.html
> > Subject: Digest Footer
> > End of Qgis-user Digest, Vol 119, Issue 49
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20160127/75897f2f/attachment-0001.html
> Message: 7
> Date: Thu, 28 Jan 2016 08:55:22 +0100
> From: Thomas Götzelt <thomasgoetzelt at web.de>
> To: Nicolas Cadieux <nicolas.cadieux at archeotec.ca>,
> Message-ID: <56A9C96A.8020605 at web.de>
> Content-Type: text/plain; charset=utf-8
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA512
> Hi,
> ALOS World 3D - 30m (AW3D30) data may be also considered an
> alternative (http://www.eorc.jaxa.jp/ALOS/en/aw3d30/), for the time
> being already available for substantial parts of Southern Asia and
> South America. Informations on how resolution and error margins of the
> dataset compare to ASTERDEM or SRTM30 will be appreciated.
> Cheers
> Thomas
> Am 27.01.16 um 21:35 schrieb Nicolas Cadieux:
> > Hi, Aster gdem are not as good with about 7 m error. They are
> > clearly canopy level models.  They cover up to 83d and srtm
> > are south and north of 60d only.  They are more detailed.
> > Nicolas Cadieux M.Sc. Les Entreprises Archéotec inc.
> > www.archeotec.ca On Jan 27, 2016 2:38 PM, "Carlos Cerdán [via
> > OSGeo.org]    " <ml-node+s1560n5247658h59 at n6.nabble.com>
> > wrote: Hi Eddison: Try r.fillnulls from Processing or directly in
> > GRASS. So, we have 30 m SRTMS in http://www2.jpl.nasa.gov/srtm/  .
> > It'll be interesting to compare with ASTER GDEM Cheers
> > 2016-01-27 13:25 GMT-05:00 Eddison Araya < [hidden email] >:
> > <blockquote style="border-left:2px solid #cccccc;padding:0
> > 1em" style="margin:0 0 0 0.8ex;border-left:1px #ccc
> > 30 meters?, in QGIS see no data areas (gaps). Thank you
> > _______________________________________________ Qgis-user mailing
> > list [hidden email] List info:
> 47652p5247658.html
> > ml-node+s1560n4125267h38@n6.nabble.com To unsubscribe from
> > Quantum GIS - User, click here . NAML
> > -- View this message in context:
> 47652p5247674.html
> > list Qgis-user at lists.osgeo.org List info:
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG/MacGPG2 v2
> Comment: GPGTools - https://gpgtools.org
> iQEcBAEBCgAGBQJWqclqAAoJEBQdD854XvN/4rAH/3kJMUSTlrpkMUfIxfnWUigw
> oX4ZXnsk9GIUTPgi/gx9WjijrF0w/bGT+83SgoOoSpcQD0875ABIDGH18oIiVCK+
> DXVVn7OO0RqrLWjlU+tf2tQCAAxrC6kjlV2au4HaRplVLGjHyBWRchXR9xY2zPcc
> dniqq9HGMoYoS7AatX8cQgp8PtTsmvaZaTM4CdCpk4xXaGbZYA8jK2AgjTxNsviq
> F/JpfdokwoDmO7iCuzcAFdYxfFHJsdR1xMArfG3WblE1eaNiRms3kKO30mHyowSR
> DBz2lPS3sh5D389gcvvKmxYMy7TDk9NMYTzmYUqJ+yxCgxJdFy6FWe6mZ5+6cF0=
> =gnTR
> -----END PGP SIGNATURE-----
> Message: 8
> Date: Thu, 28 Jan 2016 10:43:43 +0100
> From: Bernhard Ströbl <bernhard.stroebl at jena.de>
> Subject: Re: [Qgis-user] Including Images in Print Composer Templates
> Message-ID: <56A9E2CF.7070003 at jena.de>
> Content-Type: text/plain; charset=utf-8; format=flowed
> Hi,
> this is not an answer to your question but what I do is to load images
> with an URL pointing to one of our internal web servers. This works
> perfectly in templates being loaded on different machines with different
> OS, too.
> Bernhard
> Am 27.01.2016 um 00:25 schrieb David A. Riggs:
> > Hi all,
> > I'm trying to create a library of themed print composer templates for my
> > agency, and each needs to include an .SVG logo image. I would like for
> the
> > image file to A) either be included within the template file itself, or
> B)
> > referenced from a path relative to the template file.
> > It seems that when saving as a template (QGIS 2.8.3 on Win7), the .QPT
> file
> > references the image file as a relative path, but apparently relative to
> > the project rather than the template. Since I'm trying to distribute
> these
> > templates to other users, and I can't predict their filesystem layout,
> I'm
> > trying to figure out a way to reference the image relative to the
> template
> > itself.
> > I have tried editing the .QPT source in several ways to make this work:
> > 1.  <ComposerPicture file="logo.svg">
> > Simply the image filename, with the image in the same directory as the
> > template. Fails to load with a red X.
> > 2.  <ComposerPicture file="./logo.svg">
> > Relative path style "current directory" with the image in the same
> > directory as template. Fails to load because QGIS resolves the path to
> the
> > PROJECT dir rather than the template dir.
> > 3. Absolute path to the .SVG image. This works, but I don't know nor want
> > to dictate where a user places their templates.
> > 4. Relative path to project. This works, and forcing users to store
> > templates in some fixed location relative to all their projects is a
> > solution, though not one I want to force on them.
> > Is there a way to refer to an image file relative to the template itself,
> > OR a way to include the contents of an .SVG image inside the .QPT
> template?
> > Thanks!
> > - DR
> > Hi all,
> > the image file to A) either be included within the template file itself,
> > or B) referenced from a path relative to the template file.
> > file references the image file as a relative path, but apparently
> > relative to the project rather than the template. Since I'm trying to
> > distribute these templates to other users, and I can't predict their
> > filesystem layout, I'm trying to figure out a way to reference the image
> > relative to the template itself.
> > the PROJECT dir rather than the template dir.
> > want to dictate where a user places their templates.
> > itself, OR a way to include the contents of an .SVG image inside the
> > .QPT template?
> > Thanks!
> > - DR
> > David A. Riggs <david.a.riggs at gmail.com <mailto:david.a.riggs at gmail.com
> __________ Information from ESET Mail Security, version of virus signature
> database 12938 (20160128) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> End of Qgis-user Digest, Vol 119, Issue 50
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160128/3939bf1a/attachment.html>
