[Qgis-user] Joining csv and shape files in QGIS
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Wed Jul 20 22:08:55 PDT 2016
I imagine you are doing a join using the local government field or is this a spacial join?
I imagine you are using a field. Would you have an extra space before the commas? That would through things off.
Try loading the shapefile and the csv data without the join? Then, copy a government value from the shapefile then try to find it using a query or a filter in the csv. If you know it's there and can't find it, then you could have a character or something throwing off the join.
Is the gov field a unique value field?
Nicolas
On Jul 21, 2016 12:30 AM, "Phillip Money [via OSGeo.org]" <ml-node+s1560n5277479h10 at n6.nabble.com> wrote:
I am trying to join a csv file and shp file in QGIS. They both have common fields. I have imported the CSV file properly. It has two fields, a name (local government area) and an integer (total complaints per area). I have checked the properties in QGIS and they show string and int. I want to display total complaints per local government area on a map When I join the CSV and shp files, I get null values under the total complaints field. I have tried lots of things, but without success so far. Any help would be appreciated. Phillip Money
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Joining-csv-and-shape-files-in-QGIS-tp5277479.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Joining-csv-and-shape-files-in-QGIS-tp5277479p5277483.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160720/8edc9cb6/attachment.html>
