[Qgis-user] downloading a wms geoservice from QGis
Andreas Neumann
a.neumann at carto.net
Mon Nov 7 12:44:53 PST 2016
Hi Juliana,
"Save AS" as a WMS should work fine - but you need to specify a useful
extent and resolution (in map units of your projection). Otherwise it
probably fails.
I just tested it and it works fine.
The bigger question is: will CARTO allow to upload larger Geotiff files?
Did you check that?
Note that WMS are always raster. You can't convert it into a shp file.
Andreas
Am 07.11.2016 um 21:27 schrieb Juliana Mori:
> Hello,
> I have loaded a wms server to QGis, which is a raster format. As I
> need to use this in an external aplication (CARTO) which does not
> support wms, I´m trying to export the server loaded into QGIS through
> "save as" funcionality. But it´s not working.
> Do you know how I can export the wms loaded to a file (raster or shp)?
> Thanks a lot, Juliana.
> ps:: I´m working with QGis Essen, 2.14.3
> *Juliana Mori*
> www.julianamori.com <http://www.julianamori.com>
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161107/4f7d1d49/attachment.html>
