[Qgis-user] QGIS 2.16 is slowly that 2.8
Neumann, Andreas
a.neumann at carto.net
Mon Oct 3 22:19:39 PDT 2016
Hi Radek,
In that case would you please create an issue at hub.qgis.org and add
your finding, e.g. rendering in QGIS 2.8 takes xx seconds, and xx
seconds in 2.16.
You'd also need to upload your data and projects (both in 2.8 version
and 2.16 version).
This will give developers the chance to investigate.
Andreas
On 2016-10-03 22:26, Radek Červenka wrote:
> Hi Andreas
> Data is on local ssd disk.
> RCE
> 2016-10-03 16:44 GMT+02:00 Neumann, Andreas <a.neumann at carto.net>:
> Hi Radek,
> Is this about data that resides locally on your machine or from a network drive?
> Andreas
> On 2016-10-03 15:50, Radek Červenka wrote:
> Hi,
> Render in version 2.16 of big (more than 50 000 elements) vektor data (SHP, DB spatilite) is slowly than in version 2.8.
> Does anyone have experience with this problem.
> QGIS 2.16 (1-3) on windows 7-64bit
> Thank you
> RCE
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user [1]
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user [1]
Links:
[1] http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161004/78ff9165/attachment.html>
