[Qgis-user] Style editor: Custom SVG fill issue: QGIS Tutorial
Burghardt.Scholle at stadt.wolfsburg.de
Fri Oct 21 03:58:20 PDT 2016
for me it works perfect (QGIS 2.16.3, Windows 64bit). I can use my own SVG's to produce custom filled symbols. Which QGIS version do you use?
Regards
Burghardt
> -----Ursprüngliche Nachricht-----
> Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von
> Tim Bowden
> Gesendet: Freitag, 21. Oktober 2016 09:24
> An: qgis-user at lists.osgeo.org
> Betreff: Re: [Qgis-user] Style editor: Custom SVG fill issue: QGIS Tutorial
> On Fri, 2016-10-21 at 06:53 +0000, Burghardt.Scholle at stadt.wolfsburg.de
> wrote:
> > Hi Tim,
> > under "Settings -> Options -> System" you can define more SVG paths.
> > Please insert the path, in which your symbol is located.
> > Hope this helps.
> > Regards,
> > Burghardt
> Thanks, That worked when I added the path and selected the symbol that
> way, but selecting the symbol file using the file selection dialogue still didn't
> work. I take it that's a bug?
> Regards,
> Tim Bowden
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
