[Qgis-user] Ubuntu updating instructions
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Wed Sep 14 03:02:56 PDT 2016
Am 13.09.2016, 16:51 Uhr, schrieb Blumentrath, Stefan
<Stefan.Blumentrath at nina.no>:
> And if I may add:
> Even if the users are aware of the fact that ubuntugis-unstable contains
> the current releases, it can be hard to impossible >to convince a
> GIS-ignorant system administrator that it is OK to install “unstable”
> packages.
> But this issue is not a QGIS issue I guess...
Actually, this problem could be easily solved, if there was only a single
line of explanation added next to each of the repositories in the install
instructions, so the uneducated or doubtful can be told and convinced
which package ships which flavour.
And yes, I was told to change this myself and given privileges to do so a
while ago, but I couldn't find the energy to fiddle myself into the
system. And I am still confused myself, cause behaviour seems to change
 from release to release a bit.
At the moment, I can hardly write cause my right hand is in plaster and
writing and pushing a mouse is a nightmare. So could not some less
handicapped and more literate guy add some explanations to the website?
Cheers
Bernd
> From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of
> Randal Hale
> Sent: 13. september 2016 16:45
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Ubuntu updating instructions
> On 09/13/2016 10:23 AM, Jürgen E. Fischer wrote:
>> Hi Randal,
>>On Tue, 13. Sep 2016 at 00:21:21 -0400, Randal Hale wrote:
>>> It's a little bit confusing. There are like three repositories:
>>> stable, unstable, and testing. Testing you don't want (unless you
>>> want to test packages). Typically stable is a bit older. Unstable is
>>> current. Which doesn't really make sense - but that's the way it is.
>>Not like it matters much in this case.
>>We have packages in qgis.org/debian/ against the plain versions of the
>> distributions (debian and **ubuntu**) and in qgis/ubuntugis/ packages
>> against
>> newer dependencies from - and only from - ubuntugis-unstable.
>>Looks like it's hard for people to accept that there are also ubuntu
>> packages
>> in a directory called debian and that probably makes them jump on the
>> other
>> because it has ubuntu in it's name.
> I was thinking about it last night (and I was up way to late) and it is
> a bit confusing for the casual user. They've installed Ubuntu (or
> mint/debian/>xubuntu/etc) and they may not understand ubuntu is based
> off debian. So like you said - they see debian but want to use Ubuntu.
> They go to >UbuntuGIS and they see the repositories for UbuntuGIS and
> the choice is unstable (and no one likes unstable software) and stable
> (which doesn't >contain the newest software). So you end up going "Use
> Unstable because it's stable and current".
>>> Under my /etc/apt/sources.list.d directory I made a qgis.list file
>>> and put the following in there:
>>>deb http://qgis.org/debian xenial main
>>> deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu
>>> xenial main
>>Why?  That are the packages not based on ubuntugis with the
>> dependencies from
>> ubuntugis.
> Do I have this wrong? I thought I had the repositories for the install
> correct based off the directions on qgis.org. Which I could completely
> have it >wrong. With the above repos I'm getting QGIS 2.16.x and GDAL
> 2.1.x.
>>Jürgen
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Randal Hale
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611 rjhale at northrivergeographic.com
> twitter:rjhale
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160914/515b41d6/attachment.html>
