[Qgis-user] Bug copying features
Andrew amcaninch at gmail.com
Fri Apr 21 06:54:06 PDT 2017
 I filed a bug report about this a few weeks ago.
https://hub.qgis.org/issues/16351
I was using the nightly release and noticed that copying attributes worked
in some versions but not others.  I havent had the problem since I stopped
upgrading the nightly but pasting features is something I dont need to do
very often.
Andrew
On Thu, Apr 20, 2017 at 11:18 PM, Reginald Carlier <
Reginald.Carlier at ingelmunster.be> wrote:
> Hi Richard,
> Yes my second shape has a subset of attributes of the first. In fact only
> one fieldname matches with the first shape.
> In fact the first shape is a modelshape from the digirup project (Belgium)
> and the second is a modelshape from the DSI project.
> If I find the time I will test it on linux. Maybe it is a bug in windows
> only.
> Regards,
> Reginald Carlier
> Deskundige GIS
> -----Oorspronkelijk bericht-----
> Van: Richard Duivenvoorde [mailto:rdmailings at duif.net]
> Verzonden: donderdag 20 april 2017 14:42
> Aan: Reginald Carlier; 'qgis-user at lists.osgeo.org'
> Onderwerp: Re: [Qgis-user] Bug copying features
> On 20-04-17 09:26, Reginald Carlier wrote:
> > Hello,
> > I am using QGIS 2.18.6 on Windows 7 (OSGEO).
> > I am encountering a bug everytime I want to copy features from one
> > layer to another. Some fields of layer 1 are the same in layer 2.
> > As I add the layers to the project, I then set the two layers editable.
> > Then I open the attribute table of layer 1 and select all the features.
> > Then I copy all the features. Then I select layer2 and I paste all the
> > features. As a result the features are copied to layer 2 but in the
> > attribute table I can only see null values.
> > The solution for this problem is to save the project and reopen the
> > project and then do the steps mentioned here above again. Then the
> > features are copied in a correct way.
> Hi Reginald,
> I tried to reproduce your problem here with 2.18.6 (on Debian though).
> And I cannot reproduce it. I:
> - opened a dataset and saved it as a 2nd shape
> - removed all features from the 2nd shape (to have a shape with exact the
> same attributes)
> - openend both shapes in QGIS
> - copied one feature from 1 to 2
> - stopped editing of both layers
> - note: still not a saved project
> - and see the right features in 2...
> So question: is your second dataset maybe ANOTHER shape with a subset of
> the attributes of the first one?
> Anyway, this looks like an issue, feel free to create an issue for it, BUT
> make it as reproducable as possible: add small datasets to it.
> Because as you can see it's not easy to reproduce apparently :-(
> Regards,
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170421/8ab98e4e/attachment.html>
